[SOLVED] Damaged motor connector
Posted: Sun Dec 28, 2014 8:23 pm
I recently bought and assembled a crazyflie nano (1.0). When soldering it together I accidentally messed up the soldering of the M3 connector. The square pad got plugged and the round one no longer has any connectivity. By chance I discovered that I could get the motor spinning by attaching the white M3 cable directly to the transistor leg next to M3 (http://imgur.com/EhFJh9j). The black cable is attached as it should be but on the reverse side of the board. However, I do not know if this is a valid way of connecting M3? Since my crazyflie is too unstable to fly (it immediately flips over when applying thrust) I wanted to make sure the soldering isn't the cause of the problem before I continue troubleshooting.
From what I can see by plotting the performance of the motors (http://imgur.com/7XxyCYx) in the client, they are performing about equal.
Please tell me if there is any other data that might aid in analyzing the problem.
Best regards,
Alex
Best regards,
Alex
