Hi everyone,
I am developing a new function for the crazyflie, and for now I activate the new function by changing corresponded parameter in the "parameter tab". But this is very inconvenient. So I would like to change the parameter directly through pressing a certain button on joystick. I think I need to add a new button on the configuration of PS2_Mode_2, but I don't know what the id number of the button I need should be? I searched the whole project and couldn't find the function defining the mapping between the id number and the buttons.
what's the id number of each button of joystick?
Re: what's the id number of each button of joystick?
The ID of a button is defined by the joystick driver. If you use Linux, you can install jstest-gtk and see the mapping for your joystick. I am sure there are similar tools for Windows.
It works! Thanks!whoenig wrote:The ID of a button is defined by the joystick driver. If you use Linux, you can install jstest-gtk and see the mapping for your joystick. I am sure there are similar tools for Windows.
