Hi all,
I've been playing around with the neopixel_dev branch to support a NeoPixel ring mod I'm doing. The built firmware from a fresh clone of neopixel_dev HEAD is just over 60K (60456) in size. I've noticed when I have "Verify flashing" checked in the Python client during programming, the firmware will flash perfectly fine but flashing always ends with "Verification failed!" if cflie.bin is over 60K.
Flashing a cflie.bin that's under 60K results in "Flashing...done!"
In both cases, the programming was actually successful but in the case of a firmware binary >60K, the "Verify flashing" option doesn't do much for you. In the same neopixel_dev branch, I can comment out the "tiltEffect" function in modules/src/neopixelring.c and bring the cflie.bin size down to 58K (58760). Doing so results in "Flashing...done!"
So I know the "Verify flashing" checkbox isn't critical because it's doing a checksum of the uploaded firmware anyway and that a successful flash is a successful flash but I'm wondering what's magic about 60K...?
Verification failed flashing firmware over 60K...
- Contact:
Re: Verification failed flashing firmware over 60K...
Nice find. Definitely sounds like a bug. If I remember correctly the bootloader is 4K so that together with the 60K firmware will pass 64K which would make more sense...
