[SOLVED] Selecting an ultrasonic sensor and interface
Re: [SOLVED] Selecting an ultrasonic sensor and interface
It works fine with the 3.0V VCC from the deck port.
alex
Post by alex »
wrote:Alex, are you using the volage regulator that you mentioned, and if yes, where?
It seems from the pictures that you didn't use it.
And will the maxsonar sensor still work without the regulator?
Ist schön deutsche hier zu sehen. Grüsse von einem deutschen in America!
Hey, sorry for missing your post. I'm heavily into programming at the moment (see here). Need some time to implement my own altitude hold mode using the sonar sensor without harming the existing althold code (barometer).
I don't know whether you saw the latest pictures, so have a look at the CF 2.0 gallery in my signature. However, I don't use the voltage regulator any more. The sonar sensor runs fine with the 3.0 V from the VCC pin.
Ebenso, Grüße aus Bayern! :D
