MPU6050: Self test acc Y [FAIL] - motor problem?
Re: MPU6050: Self test acc Y [FAIL] - motor problem?
Have you tried tapping/banging it as described on the troubleshooting page? It seems to have worked for most accelerometer problems.
farcop
I always turning on my CF on the table.
Its strange but the problem is not ocured now. Ican fly again!
Another bug just has become. The OnOff button is crashed without any overforced action...CF is so gentle you know.
- Contact:
Hi,farcop wrote:Another bug just has become. The OnOff button is crashed without any overforced action...CF is so gentle you know.
The button is a push button, so don't try to slide it to the sides. If it's broken off then you can either turn on/off the Crazyflie by shorting the two pads on the button (on the sides) or you can have a look at the spare parts list if you would like to find a new one.
dunbarton
Just got my CF back from Seeedstudio. It works again; however, the only explanation they gave me for the MPU6050 problem was:
Could someone explain how a coat of nail polish on a motor mount can cause the
I should explain that I had painted bright green nail polish on the M1 motor mount so I could tell which direction was forward. There was no polish whatsoever on the CF board or any other parts. Moreover, it flew normally for awhile before the MPU6050 error message first appeared. The Seeedstudio techs scraped some but not all of the polish off.About the failure of the MPU-6050, we fix the problem by cleaning the paint on the motor mounter.
message?MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0
leland
Hello, my CF 10DOF (2nd batch) returned today from its journey for repair by the Seeedstudio CS/QC folks, and is now flying again!
Cheers, Leland
Cheers, Leland
- Contact:
It could be that the Y axis was stuck and during handling/scraping the axis was knocked loose again (there's more info on that earlier in this thread).dunbarton wrote: Could someone explain how a coat of nail polish on a motor mount can cause themessage?MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0
suchy
Hello I have similar problem but with Gryzo Z.
I tried to do all of the tips from your's post unfortunately no results.
And i just get this nice Crazyflie from the store.
What i should do????
SYS: Build 74:0a52a3d2d354 (2013.11-beta1) CLEAN
SYS: I am 0x871625445355755066DFF55 and I have 128KB of flash!
MPU6050: Self test gyro Z [FAIL]. low: 10.0, high: 105.0, measured: -0.24
ng!
Sng!
SYS: Build 89:54fa51cb6ea0 (2014.01.0) CLEAN
MPU6050: Self test gyro Z [FAIL]. low: 10.0, high: 105.0, measured: -0.06
ng!
Sng!
suchy, are you the one that sent an email as well?
liki
I also have this problem which shows "X[FAIL]", and there is some fluid on the surface of MPU6050. I was wondering if anyone has come across same situation with me?
