[SOLVED] Problem with the Crazyflie
KOschi
Re: Problem with the Crazyflie
Post by KOschi »
here we go with the output at my desktop computer:
bitcraze@bitcraze-ubuntu:~$ cd ~/projects/crazyflie-pc-client/cfclient/
bitcraze@bitcraze-ubuntu:~/projects/crazyflie-pc-client/cfclient$ python cfclient.py
INFO:__main__:Disabling STL printouts
INFO:utils.input:Parsing [Generic_OS_X.json]
INFO:utils.input:Parsing [PS3_Mode_2.json]
INFO:utils.input:Parsing [PS3_Mode_1.json]
INFO:utils.logconfigreader:Parsing [battery.json]
INFO:utils.logconfigreader:Parsing [memlogtest.json]
INFO:utils.logconfigreader:Parsing [mem_and_toc.json]
INFO:utils.logconfigreader:Parsing [imu_gyro.json]
INFO:utils.logconfigreader:Parsing [imu_acc.json]
INFO:utils.logconfigreader:Parsing [stabalizer.json]
INFO:ui.tabs.FlightTab:Changed flightmode to Safe and Easy
  File "/home/bitcraze/projects/crazyflie-pc-client/cfclient/ui/tabs/ServiceTab.py", line 244, in initiateColdBoot
    if self.loader.coldBoot():
  File "../cflib/bootloader/cloader.py", line 149, in coldBoot
    if self.updateInfo():
  File "../cflib/bootloader/cloader.py", line 171, in updateInfo
    cpuid = struct.unpack("B"*12, pk.data[10:])
struct.error: unpack requires a string argument of length 12
seems pretty like the same output for me. I loaded the VM again from via torrent (so i haven´t used the same maschine like on my laptop).
It seems that the client you are using is too old and not compatible with the new bootloader that is in the Crazyflie.
Could you try to get the latest version and test it again? Just do the following in the VM:
cd /home/bitcraze/projects
rm -Rf crazyflie-pc-client
hg clone https://bitbucket.org/bitcraze/crazyflie-pc-client
cd crazyflie-pc-client/bin
./cfclient
KOschi
Post by KOschi »
With this updated Client i was able to flash the Firmware. Only the verify Flashing option wasn´t working.
BUT now the next thing went wrong. When i power on the Flie the Red LED flashes fast like 5 times (i am not able to count that fast :D ) then pauses for 2 seconds and flashes again like 5 times.
The Wiki tells me "Tests failed" but not how to resolve it. Also the M1 motor is not rotating during the Self Test, could it be broken and so cause the 5 flashes?
Good to hear that the firmware update is working. Could you post the console output from within the cfclient? It will print information about the self-tests.
KOschi
Post by KOschi »
yeah offcourse:
here we go with the terminal output:
bitcraze@bitcraze-ubuntu:~$ cd /home/bitcraze/projects/crazyflie-pc-client/bin/
bitcraze@bitcraze-ubuntu:~/projects/crazyflie-pc-client/bin$ cfclient
Info: Using config path:  /home/bitcraze/.local/cfclient
Info: sys.path= ['/usr/local', '/home/bitcraze/.local/cfclient', '/usr/local/bin', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client']
INFO:cfclient.cfclient:Disabling STL printouts
INFO:cfclient.utils.config:Dist config read from /usr/local/cfclient/configs/config.json
INFO:cfclient.utils.config:Config file read from [/home/bitcraze/.local/cfclient/config.json]
INFO:cfclient.utils.config_manager:Parsing [xbox360_mode1_linux.json]
INFO:cfclient.utils.config_manager:Parsing [Generic_OS_X.json]
INFO:cfclient.utils.config_manager:Parsing [PS3_Mode_2.json]
INFO:cfclient.utils.config_manager:Parsing [PS3_Mode_1.json]
INFO:cfclient.utils.config_manager:Parsing [xbox360_mode1.json]
INFO:cfclient.ui.tabs.FlightTab:Changed flightmode to Normal
INFO:cflib.crtp.radiodriver:v0.5 dongle with serial N/A found
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/10/250K]
INFO:cflib.crazyflie:We are connected[radio://0/10/250K], request connection setup
INFO:cflib.crazyflie:Callback->Connected to [radio://0/10/250K]
WARNING:cflib.crazyflie:Got link error callback [Dongle communication error (ackStatus==None)] in state [2]
INFO:cflib.crazyflie:Callback->Disconnected from [radio://0/10/250K]
INFO:cflib.crazyflie:Callback->Connectionl ost to [radio://0/10/250K]: Dongle communication error (ackStatus==None)
WARNING:cflib.crazyflie:Got link error callback [RadioDriver: Could not send packet to copter] in state [0]
WARNING:cflib.crazyflie:ExpectAnswer: ERROR! Older timer whas running while scheduling new one on [2]
INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/10/250K]
<cfclient.ui.widgets.rtplotwidget.PlotDataSet instance at 0x8ed50ec>
<cfclient.ui.widgets.rtplotwidget.PlotDataSet instance at 0x8ed510c>
<cfclient.ui.widgets.rtplotwidget.PlotDataSet instance at 0x8ed512c>
<cfclient.ui.widgets.rtplotwidget.PlotDataSet instance at 0x8ed5d8c>
<cfclient.ui.widgets.rtplotwidget.PlotDataSet instance at 0x8ec9e2c>
<cfclient.ui.widgets.rtplotwidget.PlotDataSet instance at 0x8ed318c>
WARNING:cflib.crazyflie.log:Error when adding blockId=9, should tell listenders...
WARNING:cflib.crazyflie.log:Error when adding blockId=10, should tell listenders...
INFO:cflib.crazyflie.log:Have successfully logging for block=1
INFO:cflib.crazyflie.log:Have successfully logging for block=2
INFO:cflib.crazyflie.log:Have successfully logging for block=3
INFO:cflib.crazyflie.log:Have successfully logging for block=4
INFO:cflib.crazyflie.log:Have successfully logging for block=5
INFO:cflib.crazyflie.log:Have successfully logging for block=6
INFO:cflib.crazyflie.log:Have successfully logging for block=7
INFO:cflib.crazyflie.log:Have successfully logging for block=8
and this is what the console in the cfclient is showing:
1FF50 and I have 128KB of flash!
IMU: HMC5883L I2C connection [FAIL].
IMU: MS5611 I2C connection [FAIL].
MPU6050: Self test gyro X [FAIL]. low: 10.0, high: 105.0, measured: 0.0
the flie was standing on a flat hard surface.
DesTinY
Post by DesTinY »
The Self test of your gyro fails. Please read the post by tobias to solve this problem http://forum.bitcraze.se/viewtopic.php? ... 1924#p1757
Did it pass the self-test before you flashed new firmware on it? Have you had it flying at some point before?
If you try to power it on while moving it around a bit do you get a different measured value than 0.0?
KOschi
Post by KOschi »
I tried to "bang" on all the 4 motorsides but this didn´t help.
Also when i move it around during the powerON it still reads 0,0 as measured value.
The self test was fine before the firmware update (just the M1 Motor wasn´t working) and i also was flying with the flie without problems.
You are definitely unlucky as it looks like the gyro x-axis is broken. I think it is the first time we have a broken gyro as it before only have been the accelerometer. I think it will be very hard fixing the gyro with the "tap/bang" method.
I can make a firmware which prints out all the self tests, just to rule out a possible of a software issue, if you want (very unlikely). Else you will have to contact Seeedstudio customer support to get it replaced.
KOschi
Post by KOschi »
so all my problems started after my first attempt to update the firmware, now after the successfull update the hardware is broken? How can this be when the selftest was fine without the update?
