Broken Power Button on Crazyflie
mgooch
Re: Broken Power Button on Crazyflie
Post by mgooch »
You were correct. I managed to bridge the two legs on the IC. Did a little re soldering magic and got it to power on with out being plugged in. :mrgreen:
Thanks again so much for your help tobias. Your attention to detail and provided pictures were very much appreciated. More importantly, thank you for your time.
Great that you managed to fix it! Now you can "+up" you skill levels ;-)
taichitof
Post by taichitof »
i have more or less the same problem :(
But i onw a crazyflie 2.0.
How can i bridge it please?
Thank you for your support.
Post by chad »
taichitof wrote:Hi,
When you wrote "more or less the same problem" did you mean that your button broke off or you're having a power on/off problem...?
If it's a broken off button, I did a little post here about fixing the Crazyflie Nano (1.0) button (sorry I missed this thread OP) and since the Crazyflie 2.0 has the same button mounted in similar fashion, all of it should still apply.
