Issue with updating LPS node
ishir
Re: Issue with updating LPS node
Post by ishir »
Hi
So a bit of an update. I was able to make the UWB modules work correctly by updating the firmware using the VM. Turns out there was an issue within my Ubuntu 18.04 system only. But now while updating the crazyflie, it is frozen now and the blue LED remains on. After scouring through some similar forums, I understand that its firmware gets corrupted if VM is used to update the firmware. The forums show varied answers, so can you please help me how to correct this from within the VM?
Happy that you fixed your issue with your LPS node. But since the new issue is different, could you please start a discussion on https://discussions.bitcraze.io/ ? It is based on Github discussions so you can react with a github account. We are planning to lock this forum next week already...
We will answer as quickly as we can on your answer on the new platform
