[SOLVED] Low output sent to M4 propeller.
Re: Low output sent to M4 propeller.
All Roll trim and Pitch Trim are set to 0.
This does not sound right. Does the CF2.1 manage to calibrate? Then the read blinking LED goes from 0.5Hz blinking to 2Hz blinking. This should happen when it is placed on a stable surface.
hamakko
Post by hamakko »
After adjusting the initial value using "configure device mapping", cf2 flew well.
Probably the cause is that the initial value has been entered in pitch.
Thank you!
I'm happy you found the problem! Happy flying!
