Address configure error
whoenig
Re: Address configure error
Post by whoenig »
Can you try
roslaunch crazyflie_demo teleop_ps3.launch uri:=radio://0/20/2M/0xE7E7E7E701
Internally, std::sscanf is used for parsing, so perhaps the behavior of that is not well defined. Which OS (version)/compiler are you using?
ryanwallis
Post by ryanwallis »
Hi Whoenig,
Unfortunately that command did not work either, no data is being sent.
OS:
Ubuntu 14.04.3 LTS
and compilers:
The C compiler identification is GNU 4.8.4
-- The CXX compiler identification is GNU 4.8.4
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Using CATKIN_DEVEL_PREFIX: /tmp/catkin_test/devel
-- Using CMAKE_PREFIX_PATH: /home/jan/catkin_ws/devel;/opt/ros/indigo
-- This workspace overlays: /home/jan/catkin_ws/devel;/opt/ros/indigo
-- Found PythonInterp: /usr/bin/python (found version "2.7.6")
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /tmp/catkin_test/build/test_results
-- Looking for include file pthread.h
-- Looking for include file pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.6.14
-- BUILD_SHARED_LIBS is on
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/catkin_test/build
ryanwallis
It could still be the decoding because with:
success = std::sscanf(link_uri.c_str(), "radio://%d/%d/%d%c/%lx",...
The address becomes:
Radio Address:: 4294967295
But when it is:
success = std::sscanf(link_uri.c_str(), "radio://%d/%d/%d%c/%llx",...
print I added to crazyflie.cpp
Succes :: 1 LenSS :: 5 Vals: 0 20 2 M 996028180225
Which corresponds to:
cfclient:
INFO:cflib.crazyflie.mem:{'radio_channel': 20, 'version': 1, 'pitch_trim': 0.0, 'radio_speed': 2, 'roll_trim': 0.0, 'radio_address': 996028180225}
Though there is still no connection.
ryanwallis
Found it... This computer was missing libusb-dbg!
Thanks for all your help guys, will try everything out and report back if I still get problems
Some other niche problems I encountered:
Changing to:
in Crazyflie.cpp
And also, ROS will not connect to crazyflies if they are not power cycled after being connected to the python client (cfclient)
Strange problem bug glad that you found a solution.
About power cycling, is it happening all the time or only when changing settings? When changing radio settings the Crazyflie must be power-cycled to use the new settings.
ryanwallis
No, all the time, no idea as to why
whoenig
Post by whoenig »
There is no connection state in crazyflie_ros. What you might be seeing is that it tries to configure something, but never gets the expected message back. What you describe, could be related to https://github.com/whoenig/crazyflie_ros/issues/29, that is the cfclient configures some log blocks, the crazyflie_ros stack tries the same and currently there is no proper handling for this case. In principle, this should not happen since crazyflie_ros tries to delete all log blocks once it connects, but this might fail in your case for some other reason.
You can try the requestBatching branch of crazyflie_ros, which has proper timeout handling and some other improvements to see if that fixes your issue.
ryanwallis
Hey Whoenig, thanks for the suggestion.
I tried running:
roslaunch crazyflie_demo teleop_ps3.launch uri:=radio://0/20/2M/E7E7E7E701
But I received an error running the server, when using the requestBranch:
process[rqt_plot3-9]: started with pid [14403]
terminate called after throwing an instance of 'std::runtime_error'
what(): timeout
[INFO] [WallTime: 1477037924.979081] found update_params service
[INFO] [WallTime: 1477037924.979316] waiting for emergency service
[INFO] [WallTime: 1477037924.980327] found emergency service
[crazyflie_server-2] process has died [pid 14280, exit code -6, cmd /home/jan/catkin_ws/devel/lib/crazyflie_driver/crazyflie_server __name:=crazyflie_server __log:=/home/jan/.ros/log/fb116282-9766-11e6-b95c-18a90517f873/crazyflie_server-2.log].
log file: /home/jan/.ros/log/fb116282-9766-11e6-b95c-18a90517f873/crazyflie_server-2*.log
whoenig
Post by whoenig »
If that always happens, it is most likely related to your original problem of %llx vs. %lx in the scanf function. The error indicates that there was a timeout, i.e. the copter didn't respond within a given timeframe. Unfortunately, the error message is still generic and doesn't tell us where it is coming from exactly.
ryanwallis
Hey Whoenig, you were right, it was the scanf function.
However, I am getting an error running the server
check_vrpn_cookie(): VRPN Note: minor version number doesn't match: (prefer 'vrpn: ver. 07.33', got 'vrpn: ver. 07.20 0'). This is not normally a problem.
[ INFO] [1477135386.922091971]: Connection established
[crazyflie_server-2] process has died [pid 7136, exit code -6, cmd /home/jan/catkin_ws/devel/lib/crazyflie_driver/crazyflie_server __name:=crazyflie_server __log:=/home/jan/.ros/log/e662a0ba-9849-11e6-b9ff-18a90517f873/crazyflie_server-2.log].
log file: /home/jan/.ros/log/e662a0ba-9849-11e6-b9ff-18a90517f873/crazyflie_server-2*.log
[crazyflie2/crazyflie_add-10] process has finished cleanly
Also,
I have been getting a low-signal warning when using multiple radios.
Additionally, flying 3 crazyflies (2 off the one radio), the crazyflies have a high oscillation in only their Z-axis (I'm talking about to .3-.5m oscillation).
I am using a powered USB-Hub and have also tried a USB-USB extender to try and avoid interference.
I have a 3D printed body on the crazyflie2s to hold motion-tracking markers, so there is some extra weight, however flying solo seems to be decently stable.
Any suggestions?
