Motors dislocating when crashing the CF
Re: Motors dislocating when crashing the CF
bstott wrote: Prop Protection
http://www.thingiverse.com/thing:87149
Very nice! Do you have any figures on weight? How does the Crazyflie perform with this attached?
/Marcus
This is both a feature and a drawback. The good thing is that during a crash some of the force will be taken up by the motor will be sliding and can prevent other parts from being damaged. The drawback is that if they are not pushed back the wires might be damaged.
Adding a bit of foam tape to the bottom of the motors might be a good solution.
alex
Post by alex »
Thanks for your input, but I would like to avoid mounting something like a cage to the CF.
I found an easy protection against dislocating motors that does the job for me. Found some plastic blind plugs with an inner diameter of around 7 mm. It tightly fits the motor mounts from below after trimming the length with a cutter.
These blind plugs act as some kind of glider on the ground, protect the motor cables and successfully prevent the motors from dislocating by creating a constant force on the outside of the motor mounts.
I'll post some pictures soon.
dr.livingstone
Post by dr.livingstone »
I glued (contact glue for foamies...) some foam pads under the motors.
Actually, I used earpads cut to half in length! One drop of glue is sufficient to hold all this together.
Pierre
foosel
Post by foosel »
What do you guys think about documenting all those different great approaches for landing gear on the wiki? I started a page there in the "hacks and mods" section a couple of days back, so far only the NERF dart approach by mrb0y is featured there though.
skube
Post by skube »
Great idea foosel! I've added Pierre's hack above, which I'm going to try when I get home.
Crazyflie Nano 10-DOF | AR Drone v1 | MikroKopter Okto
VGer
Post by VGer »
Crazyflie frame v1.7 finished will post files in thingiverse tomorrow...
Have a look at my blog http://paulogeraldes.blogspot.com/2013/ ... ished.html
It is late and I need some sleep :o :o :o .
foosel wrote:What do you guys think about documenting all those different great approaches for landing gear on the wiki? I started a page there in the "hacks and mods" section a couple of days back, so far only the NERF dart approach by mrb0y is featured there though.
Great idea!
VGer wrote:Crazyflie frame v1.7 finished will post files in thingiverse tomorrow...
Nice work! We really need to get a 3D printer :(
skube
Post by skube »
That's awesome! Damn, this Crazyflie is going to force me to get a 3D printer. 8-)
