[CLOSED] Problem with IMU?
Re: (Hopefully not) Problem with IMU?
If you have access to a hot-air reflow station that is the first thing I would try, to reflow the chip again. It could be a broken sensor but we have seen very few, higher probability that it is a soldering that has cracked. Try pushing your finger against the chip when you start the test software, that could reveal a bad connection.
Call_me_a_Cab
- Member
Hi Guys got a problem here.
SYS: Build 9+:a21fee8ae81d (2014.12.0) MODIFIED
0029 and I have 1024KB of flash!
EXPBRD: Found 1 memories.
EXPBRD: Info board 0:
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
LPS25H: Self test [OK].
OW: Found 1.
OW: Serial 0xD 91 7A 8 0 0 0 72.
SYS: Free heap: 5872 bytes
EB 0 80 0 0 BC 1 23 0 E 1
Status 0
0 E 1 9 62 63 4C 65 64 52 69 6E 67 2 1 42 9D
Status 0
Status 0
Status 0
Status 0
E 67 2 1 42 9D
Status 0
Status 0
Status 0
Status 0
Status 0
Status 0
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
OW: Found 1.
Status 0
Status 0
Status 0
Status 0
Status 0
E 67 2 1 42 9D
Status 0
Status 0
Status 0
Status 0
Status 0
Status 0
Call_me_a_Cab
- Member
I now have this with Stock firmware and IMU test loaded
SYS: Build 6+:29624e7f6e3b (2014.12.0) MODIFIED
SYS: I am 0x3132383231334712240029 and I have 1024KB of flash!
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
MPU6500: Self test [OK].
IMU: Gyro variance test [OK]
IMU: Acc level test [OK]
OW: Found 1.
Status 0
Status 0
Status 0
Status 0
Status 0
OW: Cmd 0x22 timeout.
B8 3A 1 23 0 E 1 9 62 63 4C 65 64 52 69 6E 67
Status 5
Status 0
B8 3A 4C 65 64 52 69 6E 67 2 1 42 9D AA 55 55 AA
Status 5
Status 0
Status 0
Status 0
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
OW: Found 1.
Status 0
Status 0
Status 0
Status 0
Status 0
Status 5
Status 0
Status 5
Status 0
Status 0
Status 0
This is a bit strange since you don't get the "I2CDEV: Error callback nr: 1024" as in this post. And you never got it with the IMU test firmware?IMU: MPU9250 I2C connection [FAIL].
Call_me_a_Cab
- Member
Tobias,
To be honest I'm a bit lost. I've had a few different firmwares in there and all are giving weird results.
basically I was running with the latest Git firmware (modified by me to enable LED effect zero as default) and whilst flying the CF flipped and the IMU went crazy.
After this I flashed the test firmware and it was ok but again after a short while it started flipping again.
Sometimes it works, sometimes it doesn't. the latest fail I have seen is:
SYS: I am 0x313238323133471224h!
EXPBRD: Found 0 memories.
MPU6500: Self test acc X [FAIL]. low: -14.0, high: 14.0, measured: -2147483647.2147483647
OW: Found 0.
Status 0
Status 0
At this point I've lost the plot and don't even remember which firmware this was.
OW: Found 0.
Status 0
Status 0
It sounds a lot like a bad connection as well, probably a cracked solder. Try pushing your finger against the chip when you start the test software, that could reveal a bad connection. The sensor chip is the small chip on the top side in the center line beside the big chip.
Call_me_a_Cab
- Member
Pushing my finger doesnt help
I just got it flying after re flashing the latest git firmware plus my 0 effect change.
Flew for about 20 secs the flipped.
Console:
ng!
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
OW: Found 1.
Status 0
Status 0
Status 0
Status 0
B8 3A 0 0 0 0 0 0 67 2 1
Status 5
Status 0
Status 0
Status 0
30 78 42 43 0 50 0 CD CC CC 3E 66 66 A6 BF 51
Status 0
Status 0
Console:
ng!
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
OW: Found 1.
Status 0
Status 0
Status 0
Status 0
Status 5
Status 0
Status 0
Status 0
Status 0
Status 0
Something definitely happens to the sensor chip. My best guess is that is a cracked soldering and to check that the chip needs to be reflowed (solder melted). It can be done with a normal heat gun but other parts need to be heat protected. I will try to find some time and shoot a video of it during the week.
Call_me_a_Cab
- Member
Ok Great,
We have a heat gun and thermal insulation tape at work. I will youtube it. Should I expect to see any "bubbling" or other signs when heating the chip?
Actually some aluminium foil covering the board with a small hole around the chip would work well. It is the expansion port and battery connector that are the most heat sensitive.
The difficulty can be to see when the solder has melted. It tend to become a little bit more shiny but it can be hard to see. Another option is to give the chip very small nudges with a tweezers to see when it starts "floating". That it has all melted. The difficulty can be not to nudge it out of place, with a bit of carefulness it shouldn't be a problem though. There should be plenty of videos on youtube, I'll check if I can find any.
