[SOLVED]Battery connector on the CF broken
Re: Battery connector on the CF broken
Post by chad »
It's hard to see what's going on in the picture. There's too much flux splattered around. You might be able to clean it off with isopropyl (rubbing) alcohol and a small brush... Then you'll be better able to see if there are any disconnect or bridged parts still.
Also a magnifier and third-hand are essential!
sub7
Post by sub7 »
I have buy a new soldering iron with a little tip and the 3rf hand 2x not enough for a big operation.
I have warmed around the ground connector and it's OK
Thanks again !
Post by chad »
My soldering station is a Hakko FX888D that I really like. I also got this curved micro tip for it that works really well!
