MPU6050: Self test acc Y [FAIL] - motor problem?
bkolb
Re: MPU6050: Self test acc Y [FAIL] - motor problem?
Yes, this is what I tried first.
Bernd
Bernd
Then please open a support case at Seeedstudio.
dunbarton
Me too. Console report:
SYS: Build 26:5f65b66e004d (Production-V2) CLEAN
SYS: I am 0x8720142853568549675FF54 and I have 128KB of flash!
MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0
Not sure from the earlier gyro test instructions...
This began after an impact -- but not an exceptionally hard one. In fact, I'd been planning on posting my amazement at the punishment the CF can take when this happened.
Open a support case at seeedstudio, I guess...?
... whether you mean to start moving it before or after the propeller check; tried it both ways; same fail. (Powered it up on level surface both times, then picked it up and moved it around while connecting.)tobias wrote:Turn on the Crazyflie then start slowly moving it around. Connect to it and send me the same command prompt output. If the Y output still measures 0.0 then it is probably broken.
Could you try this and post the output. It's important that you start moving it just after you power it on.
bkolb
I opened a support request last week at seedstudio, however I haven't heard back from them yet... Any idea?
Kind regards,
Bernd
Kind regards,
Bernd
dunbarton
They responded to me pretty quickly on two different issues. Did you go through the seeedstudio.com Customer Service page or the Tech Support page? (I used the former.)
foosel
- Contact:
Chiming in as yet another victim of this issue:
Tried everything described in this thread, no deal, filed a ticket with Seeedstudio. Meh!
SYS: I am 0x8720424953568549669FF54 and I have 128KB of flash!
seba
Possibly have the same issue here.
My second CF was flying pretty well, but never was stable enough to hover in place. Specially when rising from ground it tend to rotate in one direction.
But today I hit it pretty hard and it felt from about 1,5m to concrete floor - seems well, but was not rising correctly, alway deviating to "front".
After power off-on sequence it won't start, flashes about 5 times in red all the time. Don't have CF here to check console now, but after reading this thread it can be broken gyro problem.
foosel
- Contact:
I know you probably don't wanna hear this, but that sounds suspiciously like what mine did, except mine was drifting to the right before power-cycling.seba wrote:seems well, but was not rising correctly, alway deviating to "front".
seba
Lucky mefoosel wrote:I know you probably don't wanna hear this, but that sounds suspiciously like what mine did, except mine was drifting to the right before power-cycling.
foosel
- Contact:
Lucky you indeed, I wish I had ordered a second 10-DOF one when they were still in stock, now I'm sh... out of luck
