Have you tried connecting to the bootloader? http://wiki.bitcraze.se/projects:crazyf ... tils:qt_ui
When you press the connect button can you see the red LED on the Crazyradio blinking?
[SOLVED] Debugdriver for UI testing
Vertikar
Re: Debugdriver for UI testing
When I try the bootloader I get [Errno 2] Entity not foundtobias wrote:Have you tried connecting to the bootloader? http://wiki.bitcraze.se/projects:crazyf ... tils:qt_ui
When I press connect I don't get LEDs lighting up on the Radio.
They do light up when I initially plug it in though, then go out.
I can see the radio in Windows device manager though.
panguitou
Thank you Tobias, that's it ! I press on [Initiate Bootloader Cold Boot] in the Crazyflie/Bootloader menu and the red led blinked and I obtained a connection :tobias wrote:Have you tried connecting to the bootloader? http://wiki.bitcraze.se/projects:crazyf ... tils:qt_ui
then I clicked on [Cancel bootloading] to quit this window and then trying the button [Connect] here it is :
It's working as well in root as in normal user mode and it flies !
Thanks so much everybody for your help and nice participation !
Jean-Marie
Vertikar
Re: [SOLVED] Debugdriver for UI testing
Unfortunately still not working for me, even after trying to re-flash it.
That said I can still see it in windows and linux so I don't think I made it any worse..
karl@home-pvr:~/bitcraze-crazyradio-firmware-bab1f83ad9b1/usbtools$ sudo python nrfbootload.py flash ../firmware/bin/cradio.bin
Found nRF24LU1 bootloader version 18.0
Flashing:
Flashing 5913 bytes...
Flashing done!
Verifying:
Reading ../firmware/bin/cradio.bin...
Reading 5913 bytes from the flash...
Verification succeded!
panguitou
On my side, I did'nt re-flash, I just clicked the [Initiate bootloader cold boot] and that was enough to initiate the connection..Vertikar wrote:Unfortunately still not working for me, even after trying to re-flash it.
Anyway it's now working and I even had my (very short) maidden flight
Here is the console tab :
Thanks again !
Jean-Marie
Vertikar
Glad you got yours working at leastpanguitou wrote:On my side, I did'nt re-flash, I just clicked the [Initiate bootloader cold boot] and that was enough to initiate the connection..Vertikar wrote:Unfortunately still not working for me, even after trying to re-flash it.
Anyway it's now working and I even had my (very short) maidden flight![]()
Thanks again !
Vertikar
Any more suggestions Tobias?
