IMU sensor upside down
Hi all,
I want to ask if someone have tryed this with current crazyflie firmware. I want to ask, if I flip motors and I have sensors upside down, stabilization algorithm will still work? if no, it's is possible to make it work with something like changing some signs or it's more complex?
Thank you!
Thank you!
Re: IMU sensor upside down
It is definitely possible and it should just be matter of changing some sign at the output of the IMU. I think we have been trying that at some point but I cannot remember the result.
The stabilizer gets the orientation here https://github.com/bitcraze/crazyflie-f ... zer.c#L278 so by modifying this function you will be able to flip the imu orientation: https://github.com/bitcraze/crazyflie-f ... #L232-L246
I've tried but I've an unexpected result.arnaud wrote:Hi,
Without any change drone goes crazy and didn't respond to RPY commands, just two motors running at maximum.
But adding this:
//Upside down
gz = -gz;Code: Select all
void sensfusion6GetEulerRPY(float* roll, float* pitch, float* yaw)
float gx, gy, gz; // estimated gravity direction
gx = 2 * (q1*q3 - q0*q2);
gy = 2 * (q0*q1 + q2*q3);
gz = q0*q0 - q1*q1 - q2*q2 + q3*q3;
//Upside down
gz = -gz;
if (gx>1) gx=1;
if (gx<-1) gx=-1;
//*yaw = atan2f(2*(q0*q3 + q1*q2), q0*q0 + q1*q1 - q2*q2 - q3*q3) * 180 / M_PI_F;
*yaw = atan2(2*(q0*q3 + q1*q2), q0*q0 + q1*q1 - q2*q2 - q3*q3) * 180 / M_PI_F;
*pitch = asinf(gx) * 180 / M_PI_F; //Pitch seems to be inverted
//*roll = atan2f(gy, gz) * 180 / M_PI_F;
*roll = atan2(gy, gz) * 180 / M_PI_F;
}I've found that, using front direction as reference and X mode, if I roll the drone on right or left it act as expected giving more power to right or left motors. But If I pitch drone in front direction or on back direction, power to motors is given in alternate way.
Here's an explanation image:
BLUE motors and RED motors activate together.
On the left is what I get if I ROLL, on the right is what I get if I PITCH and it's not as expected. Correct should be as in the center.
Where should I make changes to solve this problem?
Thank you!
I've done more tests and seems pitch and yaw inverted. I've also this problem if I try to place drone in correct position with IMU upside. That's problematic to solve for me, since I can't just flip motors order or change axis sings. Any advice on where is the problem?
Solved with changing signs in limitThurst function. Now motors seems rotating correctly.
A new problems is that when I start stabilizer function, without altHold but with manually setting thrust, I've two propeller that rush power about 20%-25% for some seconds, then calming down in some seconds. After that drone acts normally(moving it manually to see how reacts stabilizer).
But this is not a heavy problem. Main problem is that when I try to fly drone, after it reached enought speed to take fly, it start to spin on itself. I need some kind of calibration?
This sounds like you need to look at the distribute power function.
The rush you are describing could come from the yaw control loop. Since you inverted everything you should make sure that the power distribution function is still right and for example for the yaw the correction should go in the right direction.
Also for the axis, normally you should inverse 2 axis in order to keep the orientation right (ie. see right hand rule).
Thanks for your answer. I've corrected distributePower function to have correct Yaw and Pitch. I've also checked that when Yaw movement occours then correct motors turn(ex. clockwise movement - anti-clockwise motors activates).arnaud wrote:This sounds like you need to look at the distribute power function.
I've changed only dz = -dz and setted motors IDs in right order for the second axis to respect hand rule. I know that I should change axis read value sign instead to flip motors, but in this way seems the same.
But nothing changed about my main problem that two motors(that motors used for ROLL movement) starts with high thrust and then go slowly to normal 0 thrust. I've tryed to change also dy and dx sign in sensfusion6GetEulerRPY but nothing changed(just dx or dy axis are flipped like if I flip motor position).
Do you have other ideas or where can be the problem? Tomorrow I'll post sensor readings to check if it's all correct.
I'm here again! I've solved this problem, I was not correctly changing sings and not in the right place. Now after calibration is done, drone is calm an no motors running with low trust, I've also checked again if correct motor activates on each movement of roll, pitch and yaw.
But this not solved my problem that drone when going to leave ground start to slowly rotate on itself(I've noticed that is always anti-clockwise) and when have reached enough power to take off it trasforms in a flying spinning top. I hope that is becouse I should calibrate PID, but if someone have advices they are welcome!
In the case, I'll open another thread about PID calibration if I'll need help.
Thank you!
Thank you!
great that you solved some problems!
Are you based on a recent version of the firmware? The rotation at take-off was a problem and has been fixed by this code: https://github.com/bitcraze/crazyflie-f ... #L217-L226: the yaw control is done on an internal setpoint. Previously the yaw control was only on rate (degrees per seconds) and there was some drift at take-off which look like what you are observing.
