Hi all,
I was checking battery level measurment and found this levels:
3.00, // 00%
3.78, // 10%
3.83, // 20%
3.87, // 30%
3.89, // 40%
3.92, // 50%
3.96, // 60%
4.00, // 70%
4.04, // 80%
4.10 // 90%
I see a leap between 3.0v and 3.78v, and a non costant increase between other values. Are this experimental values or how did you found this levels? Also, this leap between 3.00v and 3.78v is still usable or should I cut off power below 3.78v?
Thank you!
Battery levels explaination
- Expert
- Contact:
Re: Battery levels explaination
Lithium Ion batteries are nonlinear. Sounds like the percentages were adjusted to account for this nonlinearity to present a linear domain (time?)
Here's a randomly chosen graph from the internet to illustrate:
http://www.technomadia.com/uploads/2011 ... Curve1.png
http://www.thejumperwire.com
But this are Li-Po batteries, can be applied same graph?
- Expert
- Contact:
I picked a random chart. Here's a similar graph for lipo
http://revolution-robotics.com/wordpres ... _curve.png
