Firmware Update
Firmware Update
I'm new to the crazyflie, i'm using the Crazyflie 1.0, i was trying to update the firmware, i ran the "Update all projects" script. then opened the eclipse ran the Make CLOAD make target, and then the flash using radio. the make finishes with "Reset in firmware mode...", but the crazyflie is stuck only with the blue led of the power on. i can't connect to the device with the cfclient and don't really know what to do.
any advice?
Thanks
Neta
any advice?
Thanks
Neta
Re: Firmware Update
I think, if you run the "make cload" target in the Eclipse project, it will make the Crazyflie 2 firmware by default. To make Crazyflie 1 fw, you will need to edit the make cload target and add a parameter. First you will want to run the "clean" target to get rid of the CF2 binary and object files though. So, try the following:
1) Run "clean" target in Eclipse
2) Edit the "make cload" target and add "PLATFORM=CF1" after the "CLOAD=1"
3) Run the "make cload" target again, you should get cf1.bin, cf1.elf, etc...
4) Reflash with the cf1.bin file and your Crazyflie should restart in firmware mode again and be ready to go.
5) Fly!
5) Fly!
Crazyflier - my CF journal...
Raspberry Pi Ground Control.
Mac OS X Dev Environment.
Re: Firmware Update
rediscovered my crazyflie 1.0 in the shelf, after a few flights I got this "Error when starting log config [Motors]: Block too large" (viewtopic.php?f=5&t=775) and tried to update the firmware.
No I have the same situation like Netap. Flashed successfully the crazyflie, but after powering it on the red and green led are shining shorter than 1 second and only the blue one stays on.
@chad: are you sure about necessity of configuring the makefile?! I'm working with the virtual machine 0.6 and under ~/projects there are several directories and I think 'crazyflie-firmware' is for 1.0. Same in eclipse in "Make Target" I also see 'crazyflie-firmware' and if running 'Make CLOAD' I would estimate that the firmware for 1.0 is build and flashed.
Any hint, how to fix this situation?
Regards
Thomas
Regards
Thomas
Re: Firmware Update
Hi thessy,
In late July 2015 the crazyflie-firmware on the master branch was merged to contain both firmware for Crazyflie 1 and Crazyflie 2. Now, by default, "make CLOAD" will build firmware for Crazyflie 2. You can verify this by running the "make CLOAD" target and looking at the output in the console. It will look like this:
The "cf2.elf" in the "filename" column is the elf file for Crazyflie 2.
I think the confusion is that there is a new firmware repository for the Crazyflie 2's NRF chip. That's the one called crazyflie2-nrf-firmware. This is different than the STM32 firmware (which is the micro-controller unit of the Crazyflie).
If you run the "make CLOAD" target it will build the STM32 firmware (for CF2 by default) but it won't flash it for you. The "make CLOAD" target is equivalent to running "make all DEBUG=0 CLOAD=1" on the command line. If you want to flash the firmware you build with Eclipse, you need to run the "Flash using radio" target which is equivalent to running "make cload" on the command line. The Crazyradio bootloader will happily flash a Crazyflie 2 binary to your Crazyflie 1 but the end result will be that the Crazyflie will restart, nothing will happen, and the blue light will remain lit. It can't run the CF2 firmware.
To fix this and build for Crazyflie 1, you simply tell the "make CLOAD" target that you want Crazyflie 1 firmware by setting PLATFORM=CF1 variable before running make. This is equivalent to running "make all DEBUG=0 CLOAD=1 PLATFORM=CF1" on the command line. If you already built the Crazyflie 2 firmware though, you need to run the "clean" target to get rid of the CF2 objects or you'll get an error.
Now, if you are going to flash using the Crazyradio in Eclipse (i.e. "Flash using radio" target), you have to add the "PLATFORM=CF1" to that target as well or it will look for the cf2.bin file, which will not exist since you just built cf1.bin.
So, the net takeaway here is, if you are building and flashing for Crazyflie 1 using the VM 0.6 and Eclipse, you need to edit both the "make CLOAD" target and "Flash using radio" targets by adding "PLATFORM=CF1". Alternatively, you could just create copies of both those targets, edit the copies, and rename them to something indicative of being for Crazyflie 1.
I hope my longwinded explanations helps more than hinders!
Crazyloader build!
text data bss dec hex filename
85844 1248 29856 116948 1c8d4 cf2.elf
Re: Firmware Update
Hi
i still have the same problem when i try to create a firmware.
After flash the Crazyflie Nano (CF1).
I already used the paramters PLATFORM=CF1 in command line, config.mk and i also changed it directly in Makefile.
Everything without success.
Re: Firmware Update
Hi @ ahuber1,ahuber1 wrote:Hi
In my experience, when the CF starts up, nothing happens, and the blue LED lights, it's a problem with the firmware. A few questions for you:
1) Is your crazyflie-firmware repository up-to-date and on the "master" branch before you build?
2) Are you using the Bitcraze 0.6 VM, or your own dev environment? The version of the ARM toolchain is important.
3) Have you made any modifications to the firmware? If something compiles OK but results in a runtime error, it can prevent the firmware from running.
Regards!
Re: Firmware Update
Hi @ chad,
i used several things, and after visit your site and read your blog i was able to create a right firmware.
In my VM 0.6 i forgot to switch the to the right repository.
On my Mac i compile it without the right development environment.
Thanks
Thanks
Re: Firmware Update
Great to hear it!! I'm glad my blog could help you out and that you're up and flying again.ahuber1 wrote:Hi @ chad,
Thanks
Re: Firmware Update
We really like your blog as well @chad!
Re: Firmware Update
Thank you! I'm happy to know you guys look at it too. Now I feel I'd better try harder to keep the quality, relevancy, and freshness up.tobias wrote:We really like your blog as well @chad!
