How well does altitude hold mode work?
glnnnn
Post by glnnnn »
I'm creating an autopilot for the crazyflie 2.0 and I would like to use the altitude hold feature. So after lift off and when in the air for a couple of seconds I call
cf.param.set_value('flightmode.althold', 'True');
to enable the altitude hold and I also set the thrust to 32767 which means no vertical movement. Nevertheless the crazyflie 2.0 consistently rises and crashes into the ceiling
Any ideas?
It is a closed room, no open windows or such..
Greets :)
Re: How well does altitude hold mode work?
Does it work with the python client GUI and do you get pressure measurement in the client?
What you are doing looks good, and closing the windows is a good idea :-).
