[SOLVED] Crazyflie nano cuadcopter kit 6
aybasaran10
Post by aybasaran10 » Mon Oct 19, 2015 6:15 pm
i have a problem with my crazflie. I cant see my board when i clicked scan this problem started when i flashed cfclient.bin
marcus
Re: Crazyflie nano cuadcopter kit 6
Post by marcus » Tue Oct 20, 2015 9:54 am
Does the Crazyflie still start (LEDs blinking) or is nothing blinking?
aybasaran10
Post by aybasaran10 » Tue Oct 20, 2015 6:01 pm
Not blinking
only blue blinking always when i click the buttom
Post by arnaud » Wed Oct 21, 2015 8:37 am
If you flashed with the bootloader you are still able to flash another firmware, no problem there.
You can find the latest build there: https://github.com/bitcraze/crazyflie-firmware/releases
If you flash the cf1 firmware it should restart well.
Btw what firmware did you try to flash, where did it come from?
aybasaran10
Post by aybasaran10 » Wed Oct 21, 2015 5:18 pm
I flashed oracle from vm 6.0 (projects/crazyfliefirmware/cflient.bin)
aybasaran10
Post by aybasaran10 » Wed Oct 21, 2015 8:13 pm
Thanks for everything i flashed 2015.08.1 Bin and then it worked
aybasaran10
Post by aybasaran10 » Thu Oct 22, 2015 9:47 am
yeah i made it thank you.i solved my problem.thanks to arnaud
