Do you have the detailed part number or even a datasheet for the chip antenna of the Crazyflie 2.0 (Y1 in the schematics http://wiki.bitcraze.se/_media/projects ... matics.pdf)?
Thank you!
Chip Antenna Datasheet
Re: Chip Antenna Datasheet
It's a Johanson Tech. chip antenna, 2450AT18B100. Did one of the antennas break or do you want to use it for something else (these chip antennas requires tuning to work well)?
PS. It's my 1000 post, time to celebrate with a coffee!
Thank you Tobias! Nothing broke so far - I am doing extensive testing with the RSSI readings and wanted to have a look at the specified radiation patterns.
Congratulations on your postiversary and thank you for all the quick and helpful responses:-)
I was just about to go add the antenna on the wiki spare components page but I see whoenig already did!!
Wow, he's good!
Congrats on the 1K posts Tobias - where do you find the time!?
Crazyflier - my CF journal...
Raspberry Pi Ground Control.
Mac OS X Dev Environment.
