I just purchased the CF 2.0 and can fly it off using the PC client and iOS. However, I would like to do some development and add additional sensors. I went through the wiki page and different posts and found numerous threads that explain differently. Some advice to use the VM and then they also talk about flashing firmware and then about debugging. Is there any guide/document/process which I can follow first to understand the development process. I am looking for a step-by-step procedure to understand operation.
Thank you.
Getting Started with development on CF 2.0
Call_me_a_Cab
- Member
Re: Getting Started with development on CF 2.0
Wiki Guide under construction, Should be up by the weekend.
I will post a link when it's done.
Call_me_a_Cab
- Member
Greensprings
- Member
anything comptable with windows xp?
Call_me_a_Cab
- Member
I'm sure it's very similar for importing the VM. Once that's done, It will all be relevant.
Greensprings
- Member
anyone know what version is compatable with xp, i looked at the documentation, but it wouldnt say
i tried installing 6.5 and 6.4 and it was a no go
Do not expect XP to be supported. XP is end of life, and should not be used on an internet facing computer due to the myriad of open security flaws that will never be patched.Greensprings wrote:anyone know what version is compatable with xp, i looked at the documentation, but it wouldnt say
One day our flies will drown out the sun in an autonomous Skynet of whirring motors and blinking lights.
"Thank you !! "
