import time
import struct
from threading import Timer
from binascii import *
import objc
from PyObjCTools import AppHelper
import array
objc.loadBundle("CoreBluetooth", globals(),
bundle_path=objc.pathForFramework(u'/System/Library/Frameworks/IOBluetooth.framework/Versions/A/Frameworks/CoreBluetooth.framework'))
crazyflie_service = CBUUID.UUIDWithString_(u'00000201-1C7F-4F9E-947B-43B7C00A9A08')
crtp_characteristic = CBUUID.UUIDWithString_(u'00000202-1C7F-4F9E-947B-43B7C00A9A08')
def main():
cf = BLECrazyFlie()
# add methods that the crazyflie executes
cf.add_callback(hover)
#cf.send_setpoint(0, 0, 0, 45000)
manager = CBCentralManager.alloc()
manager.initWithDelegate_queue_options_(cf, None, None)
AppHelper.runConsoleEventLoop(None, True, 'NSDefaultRunLoopMode')
def hover(cf):
# send thrust 45000
while 1:
cf.send_setpoint(50, 100, 250, 45000)
time.sleep(0.5)
# stop thrust, start hover
#cf.set_param('flightmode.althold', 'True')
#cf.commander.send_setpoint(0, 0, 0, 32767)
#while 1:
# cf.commander.send_setpoint(0,0,0,32767)
# time.sleep(0.5)
class BLECrazyFlie():
def __init__(self):
self.manager = None
self.peripheral = None
self.service = None
self.crtp_characteristic = None
self.connected = False
self.callbacks = []
def send_setpoint(self, roll, pitch, yaw, thrust):
#data = struct.pack('<fffH', roll, -pitch, yaw, thrust)
test_pk = '300000000000000000008000000000ea60'
#print struct.unpack('<idddH', test_pk)
#bytes = bytearray.fromhex(test_pk)
bytes = NSData.dataWithBytes_length_(test_pk, len(test_pk))
print bytes
self.peripheral.writeValue_forCharacteristic_type_(bytes, self.crtp_characteristic, 1)
def add_callback(self, cb):
if ((cb in self.callbacks) is False):
self.callbacks.append(cb)
def remove_callback(self, cb):
self.callbacks.remove(cb)
def call(self, *args):
for cb in self.callbacks:
cb(*args)
def centralManagerDidUpdateState_(self, manager):
if self.connected == False:
self.manager = manager
manager.scanForPeripheralsWithServices_options_(None, None)
def centralManager_didDiscoverPeripheral_advertisementData_RSSI_(self, manager, peripheral, data, rssi):
print peripheral.name()
if peripheral.name() == 'Crazyflie':
manager.stopScan()
self.peripheral = peripheral
manager.connectPeripheral_options_(peripheral, None)
def centralManager_didConnectPeripheral_(self, manager, peripheral):
print 'Connected to ' + peripheral.name()
self.connected = True
self.peripheral.setDelegate_(self)
self.peripheral.discoverServices_([crazyflie_service])
def centralManager_didFailToConnectPeripheral_error_(self, manager, peripheral, error):
print repr(error)
def centralManager_didDisconnectPeripheral_error_(self, manager, peripheral, error):
print repr(error)
AppHelper.stopEventLoop()
def peripheral_didDiscoverServices_(self, peripheral, services):
self.service = self.peripheral.services()[0]
self.peripheral.discoverCharacteristics_forService_([crtp_characteristic], self.service)
def peripheral_didDiscoverCharacteristicsForService_error_(self, peripheral, service, error):
for characteristic in self.service.characteristics():
if characteristic.UUID().UUIDString() == crtp_characteristic.UUIDString():
self.crtp_characteristic = characteristic
self.peripheral.setNotifyValue_forCharacteristic_(True, self.crtp_characteristic)
def peripheral_didWriteValueForCharacteristic_error_(self, peripheral, characteristic, error):
if error != None:
print repr(error)
else:
print 'Sent!'
def peripheral_didUpdateNotificationStateForCharacteristic_error_(self, peripheral, characteristic, error):
print 'Receiving notifications'
self.call(self)
def peripheral_didUpdateValueForCharacteristic_error_(self, peripheral, characteristic, error):
print repr(characteristic.value().bytes().tobytes())
if __name__ == "__main__":
main()
Now I'm trying to write the logic for assembling the commander packets, but the CF doesn't respond at all.
I've copied a valid commander packet from the iOS client (300000000000000000008000000000ea60, see send_setpoint), which sets the thrust to a certain value, but the CF doesn't spin the engines.
Am I missing something obvious here? I'm guessing I don't need the 0xaa, nor the checksum. Or do I?
Any help will be greatly appreciated.
