crazyflie-firmware makefile problems
georgioguido
Post by georgioguido »
Hi, I have downloaded the crazyflie-firmware. I am no expert in makefiles so I cannot solve this error when i compile:
bitcraze@bitcraze-vm:~/projects/crazyflie-firmware$ make
CLEAN_VERSION
VTMPL version.c
File "scripts/versionTemplate.py", line 55, in <module>
identify = subprocess.check_output(["hg", "identify", "-nitb"])
File "/usr/lib/python2.7/subprocess.py", line 566, in check_output
process = Popen(stdout=PIPE, *popenargs, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
scripts/targets.mk:20: recipe for target 'version.c' failed
make: *** [version.c] Error 1
What am I doing wrong?
Re: crazyflie-firmware makefile problems
This happens when compiling outside the git tree. did you download the .tag.gz.zip version of the source?
You can try to clone the git tree and the compilation should work:
git clone https://github.com/bitcraze/crazyflie-firmware
cd crazyflie-firmware
make
This is a bug, I made a ticket for it: https://github.com/bitcraze/crazyflie-f ... /issues/38
georgioguido
worked great thanks!
