Motors dislocating when crashing the CF
alex
Post by alex »
Good morning dear CF addicts,
when crashing the CF (which turned out to happen very often in the learning phase) the motors are being dislocated inside the motor mounts in the downward direction. Even though the motor mounts have some o-shaped kind of support on the inside, the motors are sliding downwards regularly. So at some point the motor cables are the lowest part of the CF and therefore are already showing some abrasion marks.
What can I do against this? I would like to avoid gluing the motors to the motor mounts. Any ideas?
marcus
Re: Motors dislocating when crashing the CF
Post by marcus »
Hi alex,
You could try something like this to protect the motors and make the landing a bit smoother.
/Marcus
foosel
Post by foosel »
Or if you happen to have access to a 3D printer take a look here. This frame by VGer protects both the motor mounts as well as the propellers, and you can also use it to mount the battery below the PCB. Comes at the price at some weight though (~3g) which makes the Crazyflie handle a bit slower and reduces battery life time a bit (the Nerf dart approach originally posted by mrb0y doesn't seem to have this issue, at least so far I didn't notice anything like that).
alex
Post by alex »
I don't have a 3D printer lying around ;), but I'll search for something like the nerf darts. Thanks for the tips.
alex
Post by alex »
Can someone please tell me the outside diameter in millimeters of the motor mount? I'm not at home but have possibly found a quick solution for protecting the motors from below.
foosel
Post by foosel »
7.49mm, 7.46 if I give some more pressure on the calipers.
Corrected after properly zero-ing the calipers
alex
Post by alex »
foosel wrote:7.49mm, 7.46 if I give some more pressure on the calipers.
Perfect, think I found something. I'll let you know if it works.
panguitou
Post by panguitou »
alex wrote:I don't have a 3D printer lying around ;)
Hi Alex, nor do I but I found out this firm in Belgium, I downloaded the file from Thingiverse and I order one copy.
For your info it will cost me 23,47 € including the shipping to France ...
I should receive it within few days !
May be you can find similar services in Germany ?
Jean-Marie
marcus
Post by marcus »
panguitou wrote:May be you can find similar services in Germany ?
For our previous prototypes we have used Shapeways, you can get the price by uploading the model there. We have used "Strong and flexible" material before but I'm not sure that it will hold for this frame,the material might be a bit brittle.
/Marcus
bstott
Post by bstott »
See fun things to do and protect your Crazyflie!
Frame Protection
http://www.thingiverse.com/thing:84169
Motor Bumper and foot pads
Bottom CF.jpg (58.44 KiB) Viewed 14282 times
USB Protection
http://www.thingiverse.com/thing:84295
Prop Protection
http://www.thingiverse.com/thing:87149
Protect your Motors and Props
