The MPU-9250 spec sheet refers the magnetometer specs as AK8963, so I guess the MPU-9250 is really a MPU-6050 with an AK8963 added. (Which is probably why the MPU-9250 can use MPU-6050 code un-modified.)
I wanted to clarify the firmware's Magnetometer code, however. I see reference to a
imu.c(line 314): hmc5883lGetHeading(&mag.x, &mag.y, &mag.z);So finally a question
Is the compass data good or do we have some more work to do in this space?
Can I use the Honeywell guide on calculating Compass Bearing with this data?
