Please help - this is driving me potty
I wanted to do some python dev with the copter on Windows. I have installed the Windows PC Client - and all the drivers and it works with a PS3 controller - so all is good
So then I install the python client and all good - except - the examples run - say ramp.py - and then dont connect - they just sit there doing nothing
The callback for connected - is not being called. If I switch off the copter - the disconnected callback works fine - but the connected one just sits there. I am using unmodified code - and I have tried a few others on the internet and these forums - but exactly the same behavior.
Lights do flash and appear to be streaming - but putting the usual debug into the code - the callback for connected simply doesnt get called
Any ideas please ?
Cannot Connect with Python Example
Re: Cannot Connect with Python Example
So anyway - I had updated my firmware recently from here https://bitbucket.org/bitcraze/crazyfli ... downloads/ I used the latest one Crazyflie_2014.01.0.bin - so I wondered if that was the issue.
So I decided to put the old firmware back - this one: cflie-2013.4.bin
And the examples start working straight away - no problem - ramp.py - nice and easy.
I also tried all this on the latest Xubuntu VM - Version 0.5 - I got same results - examples dont work.
So I guess it must be a firmware issue - however the latest Windows PC Client works perfectly with the new firmware - so I have no idea what the problem is. I also built a version from source of the cfclient - cfclient-2013.4.2 and that didnt work with the new firmware...
slight perplexed
Dave
slight perplexed
Dave
