My crazyflie now is not seen by the cfclient after power up.
This happened after I tried connecting a wireless camera to the crazyflie. I connected positive wire with pin 16 of the 20-pin holes and negative wire to pin 19. However, the soldering happened to have a short-circuit between + and - (but I don't know it when I connect to the flie.) When I put the power button, it didn't power up, but when the camera is removed, it was turned on. Trying for a few times, then I saw some smoke coming out (from the bottom, I think.)
As far as I inspect:
- PWR LED blinks once at the power up, and never lit again.
RED LED blinks normally.
At startup, all four motors still rotate.
When plugged into USB, PWR LED is not lit, GREEN and RED LED still blink, but not as bright as before.
VCC output is around 1.8-1.9 V, instead of 2.8 V.
Thanks
