[SOLVED] Crazyradio on Win7/virtual machine
alex
Re: Crazyradio on Win7/virtual machine
Post by alex »
marcus wrote:After inserting the dongle and then starting up the Bitcraze VM in VirtualBox, if you go to the menu Devices->USB Devices (in VirtualBox) what devices do you see?
See attached photo, please. Sorry for the German interface.
tobias wrote:If the Crazyradio is detected/enumerated and the driver is working the Crazyradio should blink the red LED a lot when it is scanning for Crazyflies. Can you see if it does that?
No, it's not blinking at any time, unfortuantely. Only exception is when plugging it in - as mentioned above. I'm starting to get desperate. :(
usb devices.png (39.22 KiB) Viewed 905561 times
I'm getting the feeling it's a driver issue but in the VM everything is already set-up. I've send an email to the other guys, they might have an idea.
alex
Re: Problems installing PyUSB and running CF PC Client
Post by alex »
I'm running Win7 x64 and installed the Crazyradio driver from the wiki without any problem. But as somebody said before this driver isn't needed for VirtualBox, is it? Nevertheless I didn't uninstall it, but just left it as it is. Obviously, VirtualBox knows the Crazyradio, but it maybe doesn't reach Ubuntu inside?
Thanks for your support, guys!
Just after connecting the dongle to the VM, can you open a terminal window and type "dmesg", it should display a lot of text ending with:
[  164.020130] usb 2-2: new full-speed USB device number 3 using ohci_hcd
[  164.297289] usb 2-2: New USB device found, idVendor=1915, idProduct=7777
[  164.297295] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[  164.297298] usb 2-2: Product: Crazyradio USB Dongle
[  164.297301] usb 2-2: Manufacturer: Bitcraze
[  164.297303] usb 2-2: SerialNumber: 6D07932721
Do you see something similar?
alex
Post by alex »
arnaud wrote:Hi,
Yes, I do. It's included in this text:
bitcraze@bitcraze-ubuntu:~$ dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.5.0-25-generic (buildd@lamiak) (gcc version 4.7.2 (Ubuntu/Linaro 4.7.2-2ubuntu1) ) #39-Ubuntu SMP Mon Feb 25 19:02:34 UTC 2013 (Ubuntu 3.5.0-25.39-generic 3.5.7.4)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007ffeffff] usable
[    0.000000] BIOS-e820: [mem 0x000000007fff0000-0x000000007fffffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] DMI 2.5 present.
[    0.000000] DMI: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006
[    0.000000] e820: update [mem 0x00000000-0x0000ffff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x7fff0 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR variable ranges disabled:
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] CPU MTRRs all blank - virtualized system.
[    0.000000] initial memory mapped: [mem 0x00000000-0x01ffffff]
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] init_memory_mapping: [mem 0x00000000-0x37bfdfff]
[    0.000000]  [mem 0x00000000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x379fffff] page 2M
[    0.000000]  [mem 0x37a00000-0x37bfdfff] page 4k
[    0.000000] kernel direct mapping tables up to 0x37bfdfff @ [mem 0x01ffa000-0x01ffffff]
[    0.000000] RAMDISK: [mem 0x3632a000-0x3718cfff]
[    0.000000] ACPI: RSDP 000e0000 00024 (v02 VBOX  )
[    0.000000] ACPI: XSDT 7fff0030 00034 (v01 VBOX   VBOXXSDT 00000001 ASL  00000061)
[    0.000000] ACPI: FACP 7fff00f0 000F4 (v04 VBOX   VBOXFACP 00000001 ASL  00000061)
[    0.000000] ACPI: DSDT 7fff0410 01B96 (v01 VBOX   VBOXBIOS 00000002 INTL 20100528)
[    0.000000] ACPI: FACS 7fff0200 00040
[    0.000000] ACPI: SSDT 7fff0240 001CC (v01 VBOX   VBOXCPUT 00000002 INTL 20100528)
[    0.000000] 1155MB HIGHMEM available.
[    0.000000] 891MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 37bfe000
[    0.000000]   low ram: 0 - 37bfe000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x00010000-0x00ffffff]
[    0.000000]   Normal   [mem 0x01000000-0x37bfdfff]
[    0.000000]   HighMem  [mem 0x37bfe000-0x7ffeffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00010000-0x0009efff]
[    0.000000]   node   0: [mem 0x00100000-0x7ffeffff]
[    0.000000] On node 0 totalpages: 524159
[    0.000000] free_area_init_node: node 0, pgdat c18a4940, node_mem_map f532a200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3951 pages, LIFO batch:0
[    0.000000]   Normal zone: 1752 pages used for memmap
[    0.000000]   Normal zone: 222502 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2312 pages used for memmap
[    0.000000]   HighMem zone: 293610 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x4008
[    0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[    0.000000] Found and enabled local APIC!
[    0.000000] nr_irqs_gsi: 16
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[    0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[    0.000000] e820: [mem 0x80000000-0xfffbffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[    0.000000] PERCPU: Embedded 14 pages/cpu @f7be3000 s34176 r0 d23168 u57344
[    0.000000] pcpu-alloc: s34176 r0 d23168 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520063
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.5.0-25-generic root=UUID=115869d1-90a9-4612-952d-23fc768735a2 ro quiet splash vt.handoff=7
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] __ex_table already sorted, skipping sort
[    0.000000] Initializing CPU#0
[    0.000000] allocated 4194048 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (00037bfe:0007fff0)
[    0.000000] Memory: 2049892k/2097088k available (5967k kernel code, 46744k reserved, 2934k data, 756k init, 1183688k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff15000 - 0xfffff000   ( 936 kB)
[    0.000000]     pkmap   : 0xffc00000 - 0xffe00000   (2048 kB)
[    0.000000]     vmalloc : 0xf83fe000 - 0xffbfe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf7bfe000   ( 891 MB)
[    0.000000]       .init : 0xc18b2000 - 0xc196f000   ( 756 kB)
[    0.000000]       .data : 0xc15d3de4 - 0xc18b1800   (2934 kB)
[    0.000000]       .text : 0xc1000000 - 0xc15d3de4   (5967 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:2304 nr_irqs:256 16
[    0.000000] CPU 0 irqstacks, hard=f4c08000 soft=f4c0a000
[    0.000000] vt handoff: transparent VT on vt#7
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] Fast TSC calibration failed
[    0.000000] TSC: PIT calibration matches PMTIMER. 1 loops
[    0.000000] Detected 2077.616 MHz processor.
[    0.008002] Calibrating delay loop (skipped), value calculated using timer frequency.. 4155.23 BogoMIPS (lpj=8310464)
[    0.008005] pid_max: default: 32768 minimum: 301
[    0.008033] Security Framework initialized
[    0.008050] AppArmor: AppArmor initialized
[    0.008051] Yama: becoming mindful.
[    0.008095] Mount-cache hash table entries: 512
[    0.008285] Initializing cgroup subsys cpuacct
[    0.008288] Initializing cgroup subsys memory
[    0.008297] Initializing cgroup subsys devices
[    0.008298] Initializing cgroup subsys freezer
[    0.008300] Initializing cgroup subsys blkio
[    0.008302] Initializing cgroup subsys perf_event
[    0.008539] mce: CPU supports 0 MCE banks
[    0.008661] using mwait in idle threads.
[    0.011946] SMP alternatives: switching to UP code
[    0.075079] Freeing SMP alternatives: 24k freed
[    0.075090] ACPI: Core revision 20120320
[    0.075954] ACPI: setting ELCR to 0200 (from 0e20)
[    0.076067] ftrace: allocating 24614 entries in 49 pages
[    0.084523] weird, boot CPU (#0) not listed by the BIOS.
[    0.084560] SMP motherboard not detected.
[    0.084581] Enabling APIC mode:  Flat.  Using 0 I/O APICs
[    0.088004] SMP disabled
[    0.088004] Performance Events: unsupported p6 CPU model 42 no PMU driver, software events only.
[    0.088004] NMI watchdog: disabled (cpu0): hardware events not enabled
[    0.088004] Brought up 1 CPUs
[    0.088004] Total of 1 processors activated (4155.23 BogoMIPS).
[    0.088004] devtmpfs: initialized
[    0.088004] EVM: security.selinux
[    0.088004] EVM: security.SMACK64
[    0.088004] EVM: security.capability
[    0.088004] dummy:
[    0.088004] RTC time: 19:34:24, date: 05/05/13
[    0.088004] NET: Registered protocol family 16
[    0.088004] EISA bus registered
[    0.088004] ACPI: bus type pci registered
[    0.088004] PCI : PCI BIOS area is rw and x. Use pci=nobios if you want it NX.
[    0.088004] PCI: PCI BIOS revision 2.10 entry at 0xfda26, last bus=0
[    0.088004] PCI: Using configuration type 1 for base access
[    0.088004] bio: create slab <bio-0> at 0
[    0.088004] ACPI: Added _OSI(Module Device)
[    0.088004] ACPI: Added _OSI(Processor Device)
[    0.088004] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.088004] ACPI: Added _OSI(Processor Aggregator Device)
[    0.088123] ACPI: EC: Look up EC in DSDT
[    0.088426] ACPI: Executed 1 blocks of module-level executable AML code
[    0.091336] ACPI: Interpreter enabled
[    0.091349] ACPI: (supports S0 S5)
[    0.091361] ACPI: Using PIC for interrupt routing
[    0.093447] ACPI: No dock devices found.
[    0.093454] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.093517] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.093614] pci_root PNP0A03:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.093616] pci_root PNP0A03:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.093619] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.093621] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xffdfffff] (ignored)
[    0.093622] PCI: root bus 00: using default resources
[    0.093667] PCI host bridge to bus 0000:00
[    0.093670] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.093673] pci_bus 0000:00: root bus resource [mem 0x00000000-0xfffffffff]
[    0.093737] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
[    0.094312] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
[    0.095173] pci 0000:00:01.1: [8086:7111] type 00 class 0x01018a
[    0.095784] pci 0000:00:01.1: reg 20: [io  0xd000-0xd00f]
[    0.096317] pci 0000:00:02.0: [80ee:beef] type 00 class 0x030000
[    0.098163] pci 0000:00:02.0: reg 10: [mem 0xe0000000-0xe0ffffff pref]
[    0.108754] pci 0000:00:03.0: [8086:100e] type 00 class 0x020000
[    0.110195] pci 0000:00:03.0: reg 10: [mem 0xf0000000-0xf001ffff]
[    0.112413] pci 0000:00:03.0: reg 18: [io  0xd010-0xd017]
[    0.118807] pci 0000:00:04.0: [80ee:cafe] type 00 class 0x088000
[    0.120214] pci 0000:00:04.0: reg 10: [io  0xd020-0xd03f]
[    0.121549] pci 0000:00:04.0: reg 14: [mem 0xf0400000-0xf07fffff]
[    0.122900] pci 0000:00:04.0: reg 18: [mem 0xf0800000-0xf0803fff pref]
[    0.128409] pci 0000:00:06.0: [106b:003f] type 00 class 0x0c0310
[    0.129794] pci 0000:00:06.0: reg 10: [mem 0xf0804000-0xf0804fff]
[    0.137652] pci 0000:00:07.0: [8086:7113] type 00 class 0x068000
[    0.138884] pci 0000:00:0d.0: [8086:2829] type 00 class 0x010601
[    0.140238] pci 0000:00:0d.0: reg 10: [io  0xd040-0xd047]
[    0.142935] pci 0000:00:0d.0: reg 18: [io  0xd050-0xd057]
[    0.145539] pci 0000:00:0d.0: reg 20: [io  0xd060-0xd06f]
[    0.146887] pci 0000:00:0d.0: reg 24: [mem 0xf0806000-0xf0807fff]
[    0.149469] pci_bus 0000:00: on NUMA node 0
[    0.149538] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.150601]  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e)
[    0.154843] ACPI: PCI Interrupt Link [LNKA] (IRQs *5 9 10 11)
[    0.155132] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 9 10 *11)
[    0.155226] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 9 *10 11)
[    0.155319] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 *9 10 11)
[    0.155552] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.155556] vgaarb: loaded
[    0.155558] vgaarb: bridge control possible 0000:00:02.0
[    0.155833] SCSI subsystem initialized
[    0.155913] libata version 3.00 loaded.
[    0.155965] ACPI: bus type usb registered
[    0.156009] usbcore: registered new interface driver usbfs
[    0.156009] usbcore: registered new interface driver hub
[    0.156009] usbcore: registered new device driver usb
[    0.156009] PCI: Using ACPI for IRQ routing
[    0.156009] PCI: pci_cache_line_size set to 64 bytes
[    0.156124] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.156134] e820: reserve RAM buffer [mem 0x7fff0000-0x7fffffff]
[    0.156262] NetLabel: Initializing
[    0.156264] NetLabel:  domain hash size = 128
[    0.156265] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.156274] NetLabel:  unlabeled traffic allowed by default
[    0.164009] AppArmor: AppArmor Filesystem Enabled
[    0.164009] pnp: PnP ACPI init
[    0.164009] ACPI: bus type pnp registered
[    0.164125] pnp 00:00: [bus 00-ff]
[    0.164146] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.164166] pnp 00:00: [io  0x0000-0x0cf7 window]
[    0.164184] pnp 00:00: [io  0x0d00-0xffff window]
[    0.164202] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.164219] pnp 00:00: [mem 0x80000000-0xffdfffff window]
[    0.164267] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[    0.164302] pnp 00:01: [io  0x0060]
[    0.164318] pnp 00:01: [io  0x0064]
[    0.164335] pnp 00:01: [irq 1]
[    0.164370] pnp 00:01: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.164402] pnp 00:02: [io  0x0000-0x000f]
[    0.164416] pnp 00:02: [io  0x0080-0x008f]
[    0.164429] pnp 00:02: [io  0x00c0-0x00df]
[    0.164443] pnp 00:02: [dma 4]
[    0.164474] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.164547] pnp 00:03: [irq 12]
[    0.164581] pnp 00:03: Plug and Play ACPI device, IDs PNP0f03 (active)
[    0.164606] pnp 00:04: [io  0x0378-0x037f]
[    0.164618] pnp 00:04: [io  0x0778-0x077f]
[    0.164629] pnp 00:04: [irq 7]
[    0.164658] pnp 00:04: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.165391] pnp: PnP ACPI: found 5 devices
[    0.165393] ACPI: ACPI bus type pnp unregistered
[    0.165396] PnPBIOS: Disabled by ACPI PNP
[    0.202283] Switching to clocksource acpi_pm
[    0.202315] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    0.202318] pci_bus 0000:00: resource 5 [mem 0x00000000-0xfffffffff]
[    0.202363] NET: Registered protocol family 2
[    0.202438] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.202633] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.204012] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.204012] TCP: Hash tables configured (established 131072 bind 65536)
[    0.204012] TCP: reno registered
[    0.204012] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.204012] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.204012] NET: Registered protocol family 1
[    0.204012] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[    0.204012] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[    0.204012] pci 0000:00:02.0: Boot video device
[    0.204012] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[    0.204012] PCI: setting IRQ 11 as level-triggered
[    0.204012] PCI: CLS 0 bytes, default 64
[    0.204012] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    0.204012] audit: initializing netlink socket (disabled)
[    0.204012] type=2000 audit(1367782464.200:1): initialized
[    0.226243] Trying to unpack rootfs image as initramfs...
[    0.253335] highmem bounce pool size: 64 pages
[    0.253353] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.264540] VFS: Disk quotas dquot_6.5.2
[    0.264610] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.265367] fuse init (API version 7.19)
[    0.265500] msgmni has been set to 1691
[    0.284043] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.284044] io scheduler noop registered
[    0.284044] io scheduler deadline registered (default)
[    0.284044] io scheduler cfq registered
[    0.284044] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.284062] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.284263] ACPI: AC Adapter [AC] (on-line)
[    0.284325] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[    0.284329] ACPI: Power Button [PWRF]
[    0.284411] input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input1
[    0.284414] ACPI: Sleep Button [SLPF]
[    0.286507] ACPI: Battery Slot [BAT0] (battery present)
[    0.286642] GHES: HEST is not enabled!
[    0.286705] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.290227] ACPI: Battery Slot [BAT0] (battery present)
[    0.290246] isapnp: Scanning for PnP cards...
[    0.296238] Linux agpgart interface v0.103
[    0.297560] brd: module loaded
[    0.298202] loop: module loaded
[    0.298328] ahci 0000:00:0d.0: version 3.0
[    0.299089] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
[    0.299092] PCI: setting IRQ 5 as level-triggered
[    0.299263] ahci: SSS flag set, parallel bus scan disabled
[    0.299562] ahci 0000:00:0d.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
[    0.299565] ahci 0000:00:0d.0: flags: 64bit ncq stag only ccc
[    0.299596] ahci 0000:00:0d.0: setting latency timer to 64
[    0.351155] scsi0 : ahci
[    0.351226] ata1: SATA max UDMA/133 abar m8192@0xf0806000 port 0xf0806100 irq 5
[    0.351277] ata_piix 0000:00:01.1: version 2.13
[    0.351402] ata_piix 0000:00:01.1: setting latency timer to 64
[    0.351709] scsi1 : ata_piix
[    0.351930] scsi2 : ata_piix
[    0.351973] ata2: PATA max UDMA/33 cmd 0x1f0 ctl 0x3f6 bmdma 0xd000 irq 14
[    0.351975] ata3: PATA max UDMA/33 cmd 0x170 ctl 0x376 bmdma 0xd008 irq 15
[    0.352035] Fixed MDIO Bus: probed
[    0.353054] tun: Universal TUN/TAP device driver, 1.6
[    0.353061] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.353125] PPP generic driver version 2.4.2
[    0.353185] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.353215] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.353312] ohci_hcd 0000:00:06.0: setting latency timer to 64
[    0.353330] ohci_hcd 0000:00:06.0: OHCI Host Controller
[    0.353337] ohci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 1
[    0.353381] ohci_hcd 0000:00:06.0: irq 11, io mem 0xf0804000
[    0.442774] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[    0.442779] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.442781] usb usb1: Product: OHCI Host Controller
[    0.442783] usb usb1: Manufacturer: Linux 3.5.0-25-generic ohci_hcd
[    0.442785] usb usb1: SerialNumber: 0000:00:06.0
[    0.508682] ata3.00: ATAPI: VBOX CD-ROM, 1.0, max UDMA/133
[    0.509239] ata3.00: configured for UDMA/33
[    0.520173] hub 1-0:1.0: USB hub found
[    0.520199] hub 1-0:1.0: 8 ports detected
[    0.520636] uhci_hcd: USB Universal Host Controller Interface driver
[    0.520705] usbcore: registered new interface driver libusual
[    0.520740] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[    1.304347] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.304476] ata1.00: ATA-6: VBOX HARDDISK, 1.0, max UDMA/133
[    1.304479] ata1.00: 20971520 sectors, multi 128: LBA48 NCQ (depth 31/32)
[    1.304635] ata1.00: configured for UDMA/133
[    1.398338] isapnp: No Plug & Play device found
[    1.398457] scsi 0:0:0:0: Direct-Access     ATA      VBOX HARDDISK    1.0  PQ: 0 ANSI: 5
[    1.398605] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.398675] sd 0:0:0:0: [sda] 20971520 512-byte logical blocks: (10.7 GB/10.0 GiB)
[    1.398713] sd 0:0:0:0: [sda] Write Protect is off
[    1.398716] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.398732] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.427557]  sda: sda1 sda2 < sda5 >
[    1.428494] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.428915] scsi 2:0:0:0: CD-ROM            VBOX     CD-ROM           1.0  PQ: 0 ANSI: 5
[    1.430662] sr0: scsi3-mmc drive: 32x/32x xa/form2 tray
[    1.430665] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.430758] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    1.430967] sr 2:0:0:0: Attached scsi generic sg1 type 5
[    1.538367] Freeing initrd memory: 14732k freed
[    1.540907] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.540918] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.541055] mousedev: PS/2 mouse device common for all mice
[    1.541620] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[    1.542275] rtc_cmos rtc_cmos: rtc core: registered rtc_cmos as rtc0
[    1.542335] rtc0: alarms up to one day, 114 bytes nvram
[    1.542391] device-mapper: uevent: version 1.0.3
[    1.542449] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    1.542482] EISA: Probing bus 0 at eisa.0
[    1.542530] Cannot allocate resource for EISA slot 4
[    1.542574] EISA: Detected 0 cards.
[    1.542587] cpuidle: using governor ladder
[    1.542589] cpuidle: using governor menu
[    1.542590] EFI Variables Facility v0.08 2004-May-17
[    1.542767] ashmem: initialized
[    1.542898] TCP: cubic registered
[    1.542998] NET: Registered protocol family 10
[    1.543205] NET: Registered protocol family 17
[    1.543215] Key type dns_resolver registered
[    1.543282] Using IPI No-Shortcut mode
[    1.543358] PM: Hibernation image not present or could not be loaded.
[    1.543368] registered taskstats version 1
[    1.546749] Key type trusted registered
[    1.549689] Key type encrypted registered
[    1.552767]   Magic number: 13:413:596
[    1.552905] rtc_cmos rtc_cmos: setting system clock to 2013-05-05 19:34:25 UTC (1367782465)
[    1.552963] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.552964] EDD information not available.
[    1.553087] Freeing unused kernel memory: 756k freed
[    1.553333] Write protecting the kernel text: 5968k
[    1.553354] Write protecting the kernel read-only data: 2428k
[    1.553355] NX-protecting the kernel data: 4272k
[    1.557058] usb 1-1: new full-speed USB device number 2 using ohci_hcd
[    1.582512] udevd[90]: starting version 175
[    1.754337] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.754341] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.754764] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
[    1.754766] PCI: setting IRQ 10 as level-triggered
[    1.754816] e1000 0000:00:03.0: setting latency timer to 64
[    2.228193] Refined TSC clocksource calibration: 2077.581 MHz.
[    2.228199] Switching to clocksource tsc
[    2.295072] e1000 0000:00:03.0: eth0: (PCI:33MHz:32-bit) 08:00:27:a4:c2:bf
[    2.295080] e1000 0000:00:03.0: eth0: Intel(R) PRO/1000 Network Connection
[    2.322050] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[    2.322054] EXT4-fs (sda1): write access will be enabled during recovery
[    2.329787] usb 1-1: New USB device found, idVendor=80ee, idProduct=0021
[    2.329791] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    2.329793] usb 1-1: Product: USB Tablet
[    2.329795] usb 1-1: Manufacturer: VirtualBox
[    2.348319] usbcore: registered new interface driver usbhid
[    2.348323] usbhid: USB HID core driver
[    2.371386] input: VirtualBox USB Tablet as /devices/pci0000:00/0000:00:06.0/usb1/1-1/1-1:1.0/input/input3
[    2.372440] hid-generic 0003:80EE:0021.0001: input,hidraw0: USB HID v1.10 Mouse [VirtualBox USB Tablet] on usb-0000:00:06.0-1/input0
[    2.485349] EXT4-fs (sda1): recovery complete
[    2.487442] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    2.744317] usb 1-2: new full-speed USB device number 3 using ohci_hcd
[    3.212775] usb 1-2: New USB device found, idVendor=0489, idProduct=e031
[    3.212785] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.212792] usb 1-2: Product: BCM20702A0
[    3.212797] usb 1-2: Manufacturer: Broadcom Corp
[    3.212802] usb 1-2: SerialNumber: 90004E9C5332
[    3.613048] usb 1-3: new full-speed USB device number 4 using ohci_hcd
[    4.082873] usb 1-3: New USB device found, idVendor=1915, idProduct=7777
[    4.082882] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[    4.082887] usb 1-3: Product: Crazyradio USB Dongle
[    4.082891] usb 1-3: Manufacturer: Bitcraze
[    4.082895] usb 1-3: SerialNumber: 1CAA81DDDE
[   13.168264] Adding 522236k swap on /dev/sda5.  Priority:-1 extents:1 across:522236k
[   13.204805] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.256251] udevd[295]: starting version 175
[   13.318981] lp: driver loaded but no devices found
[   13.421511] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   13.490253] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
[   13.490257] PCI: setting IRQ 9 as level-triggered
[   13.550278] input: Unspecified device as /devices/pci0000:00/0000:00:04.0/input/input4
[   13.685913] init: Failed to spawn bluetooth main process: unable to execute: Permission denied
[   13.825569] vboxguest: major 0, IRQ 9, I/O port d020, MMIO at 00000000f0400000 (size 0x400000)
[   13.825573] vboxguest: Successfully loaded version 4.2.8 (interface 0x00010004)
[   13.826837] piix4_smbus 0000:00:07.0: SMBus base address uninitialized - upgrade BIOS or use force_addr=0xaddr
[   13.875863] Bluetooth: Core ver 2.16
[   13.875887] NET: Registered protocol family 31
[   13.875888] Bluetooth: HCI device and connection manager initialized
[   13.875890] Bluetooth: HCI socket layer initialized
[   13.875892] Bluetooth: L2CAP socket layer initialized
[   13.875895] Bluetooth: SCO socket layer initialized
[   13.883014] ppdev: user-space parallel port driver
[   13.885632] parport_pc 00:04: reported by Plug and Play ACPI
[   13.902085] Bluetooth: RFCOMM TTY layer initialized
[   13.902091] Bluetooth: RFCOMM socket layer initialized
[   13.902093] Bluetooth: RFCOMM ver 1.11
[   13.922642] type=1400 audit(1367782477.866:2): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=539 comm="apparmor_parser"
[   13.926527] type=1400 audit(1367782477.870:3): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=539 comm="apparmor_parser"
[   13.954571] type=1400 audit(1367782477.898:4): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=548 comm="apparmor_parser"
[   13.958523] type=1400 audit(1367782477.902:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=548 comm="apparmor_parser"
[   13.958765] type=1400 audit(1367782477.902:6): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=548 comm="apparmor_parser"
[   13.993218] usbcore: registered new interface driver btusb
[   14.122513] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
[   14.128393] microcode: CPU0 sig=0x206a7, pf=0x1, revision=0x0
[   14.432949] init: failsafe main process (612) killed by TERM signal
[   14.625344] type=1400 audit(1367782478.570:7): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=732 comm="apparmor_parser"
[   14.625743] type=1400 audit(1367782478.570:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper//chromium_browser" pid=732 comm="apparmor_parser"
[   14.636475] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[   14.643001] Bluetooth: can't load firmware, may not work correctly
[   14.646348] type=1400 audit(1367782478.590:9): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=737 comm="apparmor_parser"
[   14.654013] type=1400 audit(1367782478.598:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=737 comm="apparmor_parser"
[   14.654257] type=1400 audit(1367782478.598:11): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=737 comm="apparmor_parser"
[   14.673737] vesafb: mode is 640x480x32, linelength=2560, pages=0
[   14.673740] vesafb: scrolling: redraw
[   14.673743] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[   14.673756] mtrr: your processor doesn't support write-combining
[   14.673810] vesafb: framebuffer at 0xe0000000, mapped to 0xf9f00000, using 1216k, total 1216k
[   14.673915] Console: switching to colour frame buffer device 80x30
[   14.673929] fb0: VESA VGA frame buffer device
[   14.765565] e1000: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[   14.792447] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.794389] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   15.498281] init: alsa-restore main process (830) terminated with status 19
[   15.736175] vboxsf: Successfully loaded version 4.2.8 (interface 0x00010004)
[   15.749190] [drm] Initialized drm 1.1.0 20060810
[   15.751809] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[   15.751819] [drm] No driver support for vblank timestamp query.
[   15.751829] [drm] Initialized vboxvideo 1.0.0 20090303 for 0000:00:02.0 on minor 0
[   16.109698] init: plymouth-upstart-bridge main process (470) killed by TERM signal
[   16.534147] init: plymouth-stop pre-start process (1233) terminated with status 1
The dongle is detected/enumerated, first step passed. When you run the cfclient and press the connect button and try after that the scan button on the pop-up window, still no blinking red LED?
alex
Post by alex »
tobias wrote:The dongle is detected/enumerated, first step passed. When you run the cfclient and press the connect button and try after that the scan button on the pop-up window, still no blinking red LED?
No LED activity at all, regardless what I do in the PC Client.
Hmmm, this is really strange. The radio chip, nRF24LU1+, on the dongle is obviously working otherwise the dongle wouldn't be found and the LEDs are also working, but it doesn't want to scan. I guess you tested different USB ports to rule out a problematic USB port?
When you run the cfclient there are some text output to the terminal you are running it from. When you press the connect button do you get:
INFO:cflib.crtp.radiodriver:v0.5 dongle with serial N/A found
alex
Post by alex »
tobias wrote:Hmmm, this is really strange. The radio chip, nRF24LU1+, on the dongle is obviously working otherwise the dongle wouldn't be found and the LEDs are also working, but it doesn't want to scan. I guess you tested different USB ports to rule out a problematic USB port?
I tried all ports without any change.
tobias wrote:When you run the cfclient there are some text output to the terminal you are running it from. When you press the connect button do you get:
No, can't find this line in the console after clicking the connect or scan button. There are some of those info lines but none with this content:
bitcraze@bitcraze-ubuntu:~/projects/crazyflie-pc-client/bin$ python cfclient
Info: Using config path:  /home/bitcraze/projects/crazyflie-pc-client/lib/../conf
Info: sys.path= ['/home/bitcraze/projects/crazyflie-pc-client/lib', '/home/bitcraze/projects/crazyflie-pc-client/lib/../conf', '/home/bitcraze/projects/crazyflie-pc-client/bin', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client']
INFO:cfclient.cfclient:Disabling STL printouts
INFO:cfclient.utils.config:Dist config read from /home/bitcraze/projects/crazyflie-pc-client/lib/cfclient/configs/config.json
INFO:cfclient.utils.config:Config file read from [/home/bitcraze/projects/crazyflie-pc-client/lib/../conf/config.json]
INFO:cfclient.utils.input:Parsing [Generic_OS_X.json]
INFO:cfclient.utils.input:Parsing [PS3_Mode_2.json]
INFO:cfclient.utils.input:Parsing [PS3_Mode_1.json]
INFO:cfclient.utils.input:Parsing [xbox360_mode1.json]
INFO:cfclient.utils.logconfigreader:Parsing [stabalizer.json]
INFO:cfclient.ui.tabs.FlightTab:Changed flightmode to Normal
