I have a SGS2 (Samsung Galaxy S2) and I installed your app. No problem to change channel and connect to my my crazyflie over OTG USB and Crazyradio.
Then there is a bug which makes flying impossible: The pad (doesn't matter which mode is set) where the Yaw is changed, hangs after each change (hangs for 1-2s after each minimal move). Normally thrust is also on this pad so i can't control my crazyflie without damage. It also doesn't matter if I'm not connected to the crazyflie, the problem is static.
On the old android client i was able to change both pads without hang (lag).
Maybe you now something about this problem or you could check this. I'm used to fly with phone pads (Droidmote
Greetings
