I have this issue on my bolt drone(with flow deck v2 and multiranger deck) where the range values from the multiranger deck and the z-ranger values would stay at the same value and freeze. Sometimes it happens right at the start, sometimes it happens mid-flight, which caused a few crashes. When this happens, the flow deck still continues to update flow values whereas the z-ranger values was stuck at a fixed value. I have checked the physical pins and ensured that they were in place. The deck also passed the self-tests at boot up in each of these occurences. Any help would be welcomed!
This is gonna sound a little stupid but we realised that the problem arose because we were tapping the 5V pins and Gnd pins for a FPV camera. So the camera was competing for power with both decks. The problem was solved when we removed the FPV camera!
