I was trying to install the driver for the loco positioning node from Zadig. However, I kept receiving the error message driver installation cancelled by users after I clicked on the install button. Can anyone help me fix this problem? I am using Windows 10. Please refer to the attached picture if that helps. Thank you.
Yu-Hsiang
							STM32 driver install
Re: STM32 driver install
A quick search shows that the cause is likely with your installation of Windows being damaged: https://github.com/pbatard/libwdi/issue ... -735964681. Can you try on another computer or another install (for example in a VM) to see if it fixes the problem.
I have tried to use another computer to install the driver. The driver is now installed successfully. However, in the LPS toll, it doesn't do anything after I click on the update button.
Could you please help me with this?
Thank you.
Thank you.
I tried to use another laptop on windows and it worked now.
