Hello
Is there instructions anywhere on how to change the camera module on the ai deck. I don’t want to unscrew anything without some help first.
Regards
Rodrigo
Ai deck camera
lorenzolamberti
Re: Ai deck camera
i swapped it.
there are two screws at the bottom. then you can unclip the camera module from the board and swap it
what i found difficult is just to keep the same pastic protection for the camera. once you unplug everything, you should extract the himax camera from the plastic protection , and you have to do it just with pressure.
