I know that in order to flow deck to work properly, it needs a very texture rich surface, with my team, we are designing a mat ourselves (because we couldn't get one with the desired measures), but I am uncertain if it is suitable for the flow deck to work well, I attach here a .pdf with the image on top of the mat, do you think it is good enough?, or could you please give me recommendations?
Thank you all in advance.
[SOLVED] Recommendations with Flow deck
santiagorg2401
- Member
- Attachments
- Mesa de trabajo 1.pdf
- (395.38 KiB) Downloaded 484 times
Last edited by santiagorg2401 on Mon Mar 01, 2021 2:08 am, edited 1 time in total.
Re: Recommendations with Flow deck
So its good that there is not any big black parts in it, which is something that the Flowdeck can not handle. However, I wonder if this won't induce any aliasing problems if it is flying on a high height... A checkerboard pattern is usually not advised.
It is better to have natural texture like a brick ground or woden floor, or even better a childern mat. Maybe something like this that you copy past until the right size?
if you have access to a print shop, it might be simpler/cheaper to print something like this . works well in the correct scale. use high contrast.
https://medialoot.com/blog/seamless-rock-textures/
santiagorg2401
- Member
Sorry for the late answering, I did not receive the notification that usually is made when someone replies a trend, I will take into account the recommendations that you gave me, thank you
