Here is the output of the console: https://pastebin.com/ZGGh4ZaJkimberly wrote: ↑Fri Aug 07, 2020 1:33 pm 1)
Oke, this is indeed a problem. What you are supposed to see is the following sequence:
- First the red and blue led are on for about 2 seconds
- then a orange led for a few seconds (which is the flashing of the FPGA firmware to the lighthouse system)
See this video for reference: https://youtu.be/QwaJC-cLHSc
- and then the blue LED is the only one on
2) I actually mean the content of the console tab, which you can toggle on under view>tabs>console in the cfclient. Could you give those instead? (by the way, first time i've seen pastebin, quite handy website!)![]()
3) The first point could have indicated that the compile didn't go as planned, since those 2 leds on (and the sequence as I explained above) means that the driver on the crazyflie firmware does not interact with the LH deck. Could you share the content of crazyflie-firmware/tools/make/config.mk here?
And here are the config.mk contents: https://pastebin.com/eRm1rZQQ
It seems like the firmware doesn't compile properly with the LH support despite make not throwing any errors. Also, I do get a lighthouse quality LED option show up (which I am pretty sure wasn't there with the previous firmware (no compile arguments given)) so that makes it a bit more odd.
