in case anyone's interested: I've recently built a large quadcopter using the Crazyflie Bolt flight controller board. Here are the basic specs of this build:
Frame: F450 (i.e. 450mm diagonal hub-to-hub "wingspan")
Motors: BLDC A2212/13T, 1000KV
ESCs: 30A
Props: 1045
Battery: 4S, 100C, 1300mAh LiPo (a bit small but I wanted to keep the weight down until the PID gains were tuned, see below)
Total flying weight: approx. 850g
Tuning the inner (rate) and outer (attitude) PID loops was a bit of a challenge
Regards
Tintin
