More Than 8 Anchor in TDoA 3
Risee
Post by Risee »
Hi all
I want to try TDoA 3 mode with more than 8 anchor
my current setup is like in the below image
How should i place more than 8 anchors (for example i want to place 12 anchor)
Where should i place anchors 8,9,10,11
https://imgur.com/a/EjbR9e5
Re: More Than 8 Anchor in TDoA 3
Post by kristoffer »
If you have a space that is "longer" in one direction, you should put them along the longest axes, close to the edge of your space. In your example between 0-5, 2-7, 3-6 and 1-4.
If you don't mind anchors in the middle of the floor, you could add them on the center of the walls (2-7-3-6 and 0-1-5-4), the ceiling and floor.
You can try to add one anchor at a time to see how many you need. It might for instance be enough to add two anchors on the floor (easier than in the ceiling).
