struct.error: unpack requires a buffer of 1 bytes
Duncan
Post by Duncan »
I encountered some issues when I try to read the log variables. I write some codes to read the log variable and do some math. It work well at the beginning and read the desired log variables without any problem. But then, after updating a few hundred times, the code crashed and shows the following error message: (the Crazyflie firmware did not crash)
Exception while doing callback on port [5]
File "C:\Users\samsung pc\Desktop\crazyflie-lib-python-master\cflib\crazyflie\__init__.py", line 396, in run
cb.callback(pk)
File "C:\Users\samsung pc\Desktop\crazyflie-lib-python-master\cflib\crazyflie\log.py", line 580, in _new_packet_cb
block.unpack_log_data(logdata, timestamp)
File "C:\Users\samsung pc\Desktop\crazyflie-lib-python-master\cflib\crazyflie\log.py", line 307, in unpack_log_data
unpackstring, log_data[data_index:data_index + size])[0]
Any advice would help.
Thanks in advance.
Duncan
Re: struct.error: unpack requires a buffer of 1 bytes
I do not recognize this error. Is it happening during connection after a while or at connection all the time?
The best is if you could make a minimal script that shows the problem, this way we could try to reproduce it on our side.
Duncan
Post by Duncan »
Hi, arnaud
Those log readings are from the extra sensor through the Crazyflie so might be you could regenerate this error by reading other log parameters.
The code below is the only log reading-related part in the client code. The firmware side to register log variables is similar to the "oa" deck driver.
def receive_rssi(scf, lm_marker):
    print('Waiting for reading rssi value...')
    t_log_config = LogConfig(name='Target', period_in_ms=500)  # the log group name is target
    t_log_config.add_variable('target.rssi1', 'int8_t')
    t_log_config.add_variable('target.rssi2', 'int8_t')
    t_log_config.add_variable('target.rssi3', 'int8_t')
    t_log_config.add_variable('target.rssi4', 'int8_t')
    t_log_config.add_variable('target.rssi5', 'int8_t')
    a_log_config = LogConfig(name='Anchor', period_in_ms=500)  # the log group name is anchor
    a_log_config.add_variable('anchor.rssi6', 'int8_t')
    a_log_config.add_variable('anchor.rssi7', 'int8_t')
    rssi1 = -128
    rssi2 = -128
    rssi3 = -128
    rssi4 = -128
    rssi5 = -128
    rssi6 = -128
    rssi7 = -128
    with SyncLogger(scf, t_log_config) as logger:
        for log_entry in logger:
            data = log_entry[1]
            rssi1 = data['target.rssi1']
            rssi2 = data['target.rssi2']
            rssi3 = data['target.rssi3']
            rssi4 = data['target.rssi4']
            rssi5 = data['target.rssi5']
            # check whether rssi value is updated
            if rssi1 !=-128 or rssi2 !=-128 or rssi3!=-128 or rssi4!=-128 or rssi5!=-128:
               break
    with SyncLogger(scf, a_log_config) as logger:
            data = log_entry[1]
            rssi6 = data['anchor.rssi6']
            rssi7 = data['anchor.rssi7']
            if rssi6 !=-128 or rssi7 !=-128:
               break
The error happens during connection after a while. At first, the reading and data transmitting have no problem at all but after like reading 200 times, the client shows that error.
Thank you very much,
Duncan
The script you sent is not a workable script, it would be much more useful if you could send a minimal working example so that I can experiment with exactly the same code from here. The script should contain the minimum amount of code to work our of the box and show the problem.
I anyway tried to run the sync log demo (https://github.com/bitcraze/crazyflie-l ... logSync.py) modified to run for 10 minutes and I did not get any error. So basic use of sync log API with the latest version of the lib and the firmware seems to work.
Duncan
Post by Duncan »
Cool. So I will try to the latest version and see whether the error happens again.
Thanks.
Duncan
Duncan
Post by Duncan »
Hi Arnaud,
I think I find another key to this error after I modified the sync log demo code to the way I use the log in my code.
Here is the code:
import logging
import time
import cflib.crtp
from cflib.crazyflie.log import LogConfig
from cflib.crazyflie.syncCrazyflie import SyncCrazyflie
from cflib.crazyflie.syncLogger import SyncLogger
# Only output errors from the logging framework
# URI to the Crazyflie to connect to
uri = 'radio://0/80/2M'
def log_read(scf):
    lg_stab = LogConfig(name='Stabilizer', period_in_ms=100)
    lg_stab.add_variable('stabilizer.roll', 'float')
    lg_stab.add_variable('stabilizer.pitch', 'float')
    endTime = time.time() + 0.1
    with SyncLogger(scf, lg_stab) as logger:
            timestamp = log_entry[0]
            data = log_entry[1]
            logconf_name = log_entry[2]
            if time.time() > endTime:
                print('[%d][%s]: %s' % (timestamp, logconf_name, data))
                break
if __name__ == '__main__':
    # Initialize the low-level drivers (don't list the debug drivers)
    # Scan for Crazyflies and use the first one found
    print('Scanning interfaces for Crazyflies...')
    print('Crazyflies found:')
    count = 0
    with SyncCrazyflie(uri, cf=Crazyflie(rw_cache='./cache')) as scf:
        while 1:
            log_read(scf)
            count += 1
            print(count)
            time.sleep(0.2)
So every time I run this code, it works at the beginning but the log reading would strictly stop and the program gets stuck at the 256th reading.
Thanks.
Duncan
Thanks for the working example! I can reproduce the problem on my side.
Your code is continiously creating and deleting log blocks and it seems that doing that more than 256 times does not work. Each log block is assigned a 1 byte ID by the Crazyflie and what is seems is that the ID are not re-used when a block has been removed. There is a bug somewhere, either in the lib or in the Crazyflie. I am looking at where the problem might be and will create a ticket in the correct project.
Do you really need to stop and start logging? A more common way would be to use the async log API and to setup log callbacks for all your crazyflies. That way you do not have to start and top log and this problem will not appear.
Duncan
Post by Duncan »
Thank you very much. If always keep the logging then it would require something like the threading, right? Since the data collection would only happen in some situations, I still hope the logging could start and stop. Could you share with me some materials and resources about the async log API? I don't find them in the examples.
Duncan
The basiclog example is using the async API: https://github.com/bitcraze/crazyflie-l ... asiclog.py.
One thing to do is indeed to keep the script alive. In this simple example this is done with a loop waiting for the Crazyflie to disconnect: https://github.com/bitcraze/crazyflie-l ... #L142-L143.
Duncan
Post by Duncan »
Thank you so much.
