Hi Lombazombie,
The bottom deck is an optiflow deck.
I had solved my problem like this:
I wanted to solder the two long connectors, but I am bad at it and threw two of them in the garbage.
So next I put the multiranger on a new set of long connectors, and 3d printed a box just a bit taller than the battery. I used it to basically guide the multiranger deck on the long connectors to the remainder of the decks. Then very slowly I soldered the two connectors together.
Even with that, its a bit crooked, but at least it works.
I suggest you guys find some pin-connector-thingie that you sell, so we dont have to resort to soldering.
Here's the end result.
Lombazombie wrote: ↑Fri Sep 20, 2019 9:19 pm
Hey r0b0tn1k,
Is there a deck on the bottom? It looks like its being stopped from going all the way up.
We actually ran into this issue as well since we had a custom deck that was a bit bigger. What we had to end up doing was removing that black part from the pins and individually pushing them through. I can probably post pictures later tomorrow or Monday.
Thanks.
