Are all the anchors and Crazyflie updated with the latest firmware? Normally clicking the write button should make all the boxes becomes red and then green when the value is confirmed to be written in the anchors.
						Loco Positioning System Setup
Re: Loco Positioning System Setup
all parts of the system are updated to the latest firmware version. In the meantime, I found the error and would like to share my solution for others:
I connected each node to the computer via USB. I then used "sudo picocom /dev/ttyACM0" for serial access to the node (picocom can be installed via "sudo apt install picocom"). Note that the device may be different: it could be ttyACM1 or so on. Once connected, I pressed "r" to show the radio settings menu and then selected the first option, corresponding to "normal bandwidth, normal preamble", the default setting, which is required for both TWR and TDoA2 to work. The nodes were previously using "low bandwidth, long preamble" for some strange reason.
After setting all nodes to "normal bandwidth, normal preamble", I could see the green indications in the client. I still get some unexplainable drop-outs from some anchors sometimes, which results in completely random behaviour of the Crazyflies and crashes, but this is not the issue of the current thread anymore.
Regards, Andy
Regards, Andy
Hi Andy,
Thanks for the update!
Where your not fresh from factory or where they used by someone else before? Tweaking the radio settings can indeed affect the communication between the Crazyflie and the nodes.
Hi Arnaud,
my anchors were freshly purchased and I hadn't done anything but flash the latest firmware on them and configuring their IDs following your tutorial. Anyway, now that their radio settings are configured correctly, I don't encounter many connection problems anymore.
My position estimation is still very off sometimes, which causes a lot of crashes and does not enable me to run the example scripts confidently. I use 6 anchors in TWR mode in an area of approximately 6m x 7.5m x 2m. I notice that someone approaching the drone considerably worsens the positioning up to complete randomness. Do you think that other radio signals around the flying area could cause interference problems or what other reasons could it have?
Best, Andy
Best, Andy
From where can I download the master version of crazyclient
I am also facing the same issue
No Anchors are coming on my crazy client
Hi @andy. With this system size you most likely have problem with the range: with default settings the ancors work very well in a system that is 4x4x3 meters, a bit more is possible but much more requires to change the radio settings.
We have a couple of scripts that can be used to set the anchors radio output power and settings: https://github.com/bitcraze/lps-node-fi ... /tools/lpp. with these script you can set your anchor to max transmit power which should help a lot.
The only problem is that we do not have this kind of settings (yet) available in the Crazyflie, the Crazyflie UWB radio can only transmit at normal power and in TWR mode there is communication in both direction so you need the Crazyflie to increase transmit power as well (in TDoA mode the Crazyflie only receives). Though, this is something that would be quite easy to add to the Crazyflie. If you add the following code around this line https://github.com/bitcraze/crazyflie-f ... eck.c#L439
The Crazyflie radio will be set to max power.
@envoy, if you are on windows you can download the client build for master from appveyor: https://ci.appveyor.com/project/bitcraz ... /artifacts. For other OSes follow the readme: https://github.com/bitcraze/crazyflie-c ... c-client--. If you still have problems setting up the LPS please create a new forum thread explaining where you are in the getting started process and how are the LEDs blinking on both the Crazyflie LPS deck and the LPS nodes.
dwSetTxPower(dwm, 0x1F1F1F1Ful);@envoy, if you are on windows you can download the client build for master from appveyor: https://ci.appveyor.com/project/bitcraz ... /artifacts. For other OSes follow the readme: https://github.com/bitcraze/crazyflie-c ... c-client--. If you still have problems setting up the LPS please create a new forum thread explaining where you are in the getting started process and how are the LEDs blinking on both the Crazyflie LPS deck and the LPS nodes.
Hi Arnaud,
I can confirm that I had the same issue as Andy, i.e., the anchors somehow had "low bandwidth, long preamble" radio setting instead of the default "normal bandwidth, normal preamble" after opening the package.
And, similarly changing the setting to "normal bandwidth, normal preamble" made the anchors visible which was not the case before.
Regards,
Rohan
Regards,
Rohan
