GPS connection problem
melomel
Post by melomel »
Hi there. I'm newbie about crazyflie and I would like to connect a gps module to it. I made a connection by using TX and RX pins but I cannot manage to get a data from gps module. What do I have to do to get a data from gps module? By the way I'm using ublox 7m Neo.
melomel
Re: GPS connection problem
Post by melomel »
I try to use bigquad deck also but i cannot manage to get a data from gps.
As there is only experimental code using GPS can you share how you connect it and how you interface it?
melomel
Post by melomel »
At first, I connected gps module to bigquad deck's gps port and then I added gps tab to crazyflie client's plotter but I didn't see any data in there. And then I connected gps module directly to crazyflie's rx1 and tx1 pins but I get nothing again.
I try to find a solution with respect to this link https://www.bitcraze.io/2014/03/crazyfl ... s-round-2/ But I cannot manage to get a data from gps module.
It'll be nice for me to learn what kind of changes needed in firmware or in hardware to get a gps data.
santiagorg2401
Post by santiagorg2401 »
Did you manage to receive the GPS data?
