I am just using a python code from cflib to communicate to the crazyflie, but hover command does not seem to work. Also I find lot of delay while communicating to the quad, about 2 secs. Any reasons for the same? Using some bit of mechanics, isn't the hover thrust equal to the m*g of the quad? If I simply pass on this much thrust, wont the quad hover? I have attached my code. Any input is very helpful since I am new to this field!
roll = 0
pitch = 0
yawrate = 0
thrust = 39000
crazyflie.commander.send_setpoint(0, 0, 0, 0)
for i in range(1,60):
# take off
if i < 10:
crazyflie.commander.send_setpoint(roll, pitch, yawrate, thrust)
time.sleep(0.1)
# for hovering
else:
thrust = 37900
time.sleep(0.1)
print ('Sending data..', thrust)
Hover using cflib
Re: Hover using cflib
Hi, I am not sure why you are experiencing delay. Can you maybe copy a fully working example (you can create a code block in the forum post to make to copy the code, keeping spaces is very important for python code
You code will definitely make the Crazyflie take-off, but not really hover. If you send a raw thrust and 0 as roll/pitch/yaw the Crazyflie will drift away.
To be able to hover the Crazyflie needs some information about its position or velocity in the room. One way to achieve that is with the Flow deck. When the Crazyflie has a flow deck installed, or when it knows its position with other means, you can use hover setpoint to set the height and the x/y velocity. For example: https://github.com/bitcraze/crazyflie-l ... ync.py#L59.
Ps. Since this is a new question I moved your post in a new topic.
I am planning to use Motion Capture system for closed loop control, however, the delay is causing the quad to behave in a bizarre way. I have attached my code for open loop only. If you could just tell me why the delay comes up. Also, can I use the estimatedZ value of the Log group, "posEstimatorAlt" to do a closed loop control? Now I feel Flow deck is playing an important role though!
import logging
import time
from threading import Thread
import cflib
link_uri = "radio://0/50/2M"
crazyflie = Crazyflie()
crazyflie.connected.add_callback(link_uri)
crazyflie.open_link(link_uri)
print('Connecting to %s' % link_uri)
roll = 0
pitch = 0
yawrate = 0
thrust = 37000
for i in range(1,30):
# take off
if i < 10:
time.sleep(0.1)
# increase height
elif i > 10 and i < 15:
thrust = 38000
crazyflie.commander.send_setpoint(0, 0, yawrate, thrust)
time.sleep(0.1)
# for hovering
else:
roll = 0
pitch = 0
thrust = 36000 # just about enough to balance weight
time.sleep(0.1)
Fland = thrust
while Fland > 20000:
Fland += -500
crazyflie.commander.send_setpoint(roll, pitch, yawrate, Fland)
time.sleep(0.1)
print (Fland)
crazyflie.close_link()
If you want to close the loop with a Mocap outside the Crazyflie you should not use any of the position estimate from within the crazyflie, then using roll/pitch/yawrate/thrust packet is indeed the way to go, you will only get position and velocity feedback from your mocap in that case.
If you have a MOCAP, you most likely do not need the flow deck, unless you want to do experiment on the flow deck using the MOCAP as ground truth.
I ran your code and I am not sure I see any delay, it does not ballance my Crazyflie though
(it gets to the ceiling and go back down). Though, I can see a fundamental problem: you are not waiting for the Crazyflie to be connected to start sending commands, before the connected callback is called, the lib is fetching a lot of data and that can cause latency. I modified your code to wait for connection.
What are you trying to achieve? If you want to work on a position controller, your approach is good. However if you want to work on an autonomous Crazyflie the best is to push the mocap position to the Kalman filter and let the kalman filter calculate a position estimate, you will then be able to use the on-board position control loop. You can send external position with cf.extpos.send_extpos(). You will need to recompile the Crazyflie with "ESTIMATOR=kalman" in config.mk in order to force the kalman filter as default estimator.
import logging
import time
import cflib
link_uri = "radio://0/45/2M"
connected = False
def on_connected(uri):
global connected
connected = True
crazyflie.connected.add_callback(on_connected)
while not connected:
pass
print('Connected!')
roll = 0
pitch = 0
yawrate = 0
thrust = 37000
# take off
if i < 10:
time.sleep(0.1)
# increase height
thrust = 38000
time.sleep(0.1)
# for hovering
else:
roll = 0
pitch = 0
time.sleep(0.1)
Fland = thrust
Fland += -500
time.sleep(0.1)
print (Fland)
I shifted to ROS and MATLAB for the implementation of the controllers and kalman estimator. Everything works fine for a single Crazyflie. Looking forward to control multiple via a single radio. Thanks again for the support! I figured out we cannot optimally stabilize real systems with a feed forward control which was what I was trying, we definitely need a feedback. Cheers
Would you please share the launch file you used?
I was hoping to use extpos() class and commander to send external position set points but I'm not quite sure how to set up Optitrack with my drone in the script and couldn't find anything online yet?
Thanks
Thanks
Hi karishma2617,
Can you share matlab model with us. I am looking for matlab model that can be communicate with crazyflie.
karishma2617 wrote: ↑Thu Jul 26, 2018 7:09 am Hi,
I shifted to ROS and MATLAB for the implementation of the controllers and kalman estimator. Everything works fine for a single Crazyflie. Looking forward to control multiple via a single radio. Thanks again for the support! I figured out we cannot optimally stabilize real systems with a feed forward control which was what I was trying, we definitely need a feedback. Cheers![]()
