This is most likely a problem with access right. You can try to run your script with sudo, if it works with sudo there is access right problem.
You can create a udev rule file to solve the problem: https://github.com/bitcraze/crazyflie-l ... ermissions
After the udev rules file has been created, remove and re-insert the radio and you should be able to use it without sudo.
Sending control message failed, Windows 10
Re: Sending control message failed, Windows 10
I have just tried running a basic script using a sudo command and the same thing happens. I am not sure what to try next.
Is there anything different I need to do to get this working with a raspberry pi at all?
Can you maybe describe a bit more what does not work. Ie. what are you running, what is the intended result and what is your observed result?
Certainly, the code I'm running is partly the test code you suggested. I then set the power output and tell the radio to produce a continuous wave:
The error I am receiving is this:
from crazyradio import Crazyradio
cr = Crazyradio()
cr.send_packet([0xff])
POWER_SETTING = 2
cr.set_power(POWER_SETTING)
cr.set_cont_carrier(True)
When I run this on Windows is runs fine, but this error keeps occurring on my Pi.
File "piradiotest.py", line 3, in <module>
cr = Crazyradio()
File "/home/pi/crazyradio-firmware/lib/crazyradio.py", line 123, in __init__
raise Exception("Cannot find a Crazyradio Dongle")
Exception: Cannot find a Crazyradio Dongle
Do you see the radio when typing "lsusb" and does the radio appear in "dmesg" just after inserting it in the Raspberry pi.
What happen if you are running this script with sudo?
It is not listed when I run lsusb. The message I posted previously happens with and without the sudo command.
I have solved this! I had to change to use a USB power adapter to connect the radio to my Pi. I switched this back afterwards and I noticed that a Nordic Device was now showing in lsusb. I ran my code with sudo and this works perfectly the same as I had it on a Windows 10 machine. Thank you for your help!
Great! Glad that the problem is solved
