What am I doing wrong?
I have 2 crazyflies (CF2.0) flashed with 2016.09 zip files. Both pass self check and spin props but that's it.
I can connect to them with cfclient, but moving throttle input doesn't do anything. Also, artificial horizon doesn't update.
also python -m examples.ramp show this but doesn't spin props:
Scanning interfaces for Crazyflies...
Crazyflies found:
radio://0/80/2M
Connecting to radio://0/80/2M
python -m examples.basicparam seems to get all the parameters ok.
Here is cfclient console:
SYS: Build 0:83c188aa9f51 (2016.09) MODIFIED
SYS: I am 0x30323536313551104A002A and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
IMU: MPU9250 I2C connection [OK].
IMU: AK8963 I2C connection [OK].
IMU: LPS25H I2C connection [OK].
DECK_DRIVERS: Found 7 drivers
DECK_INFO: Found 0 deck memory.
DECK_CORE: 0 deck enumerated
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
SYS: Free heap: 12840 bytes
And here is console log for cfclient:
$ bin/cfclient
INFO:cfclient.gui:Disabling STL printouts
INFO:cfclient.utils.input.inputreaders:Found readers: ['linuxjsdev', 'pysdl2']
INFO:cfclient.utils.input.inputreaders:Successfully initialized [linuxjsdev]
INFO:cfclient.utils.input.inputreaders:Could not initialize [pysdl2]: No SDL2 support on Linux
INFO:cfclient.utils.input.inputinterfaces:Found interfaces: ['leapmotion', 'wiimote', 'zmqpull']
INFO:cfclient.utils.input.inputinterfaces:Could not initialize [leapmotion]: Leap Motion library probably not installed (No module named 'leapsdk')
INFO:cfclient.utils.input.inputinterfaces:Could not initialize [wiimote]: Missing cwiid (wiimote) driver No module named 'cwiid'
INFO:cfclient.utils.config:Dist config read from /home/miles/projects/crazyflie-clients-python/src/cfclient/configs/config.json
INFO:cfclient.utils.config:Config file read from [/home/miles/.config/cfclient/config.json]
INFO:cfclient.utils.input.inputinterfaces:Could not initialize [zmqpull]: ZMQ input disabled in config file
INFO:cfclient.utils.zmq_param:Biding ZMQ for parameters at tcp://*:1213
INFO:cfclient.utils.zmq_led_driver:Biding ZMQ for LED driverat tcp://*:1214
INFO:cfclient.utils.input:Using device blacklist [(VirtualBox|VMware)]
INFO:cflib.crtp.radiodriver:v0.53 dongle with serial N/A found
INFO:cfclient.utils.input:Selected MUX: Normal
INFO:cfclient.ui.main:Role of Sony Computer Entertainment Wireless Controller is Device
INFO:cfclient.utils.input.mux:Adding device Sony Computer Entertainment Wireless Controller to MUX Normal
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/80/2M]
INFO:cflib.crazyflie:We are connected[radio://0/80/2M], request connection setup
INFO:root:Has safelink: True
INFO:cflib.crazyflie:Resending for pattern (93, 5)
INFO:cflib.crazyflie:Callback->Connected to [radio://0/80/2M]
INFO:cflib.crazyflie.mem:Requesting number of memories
INFO:cflib.crazyflie.mem:2 memories found
INFO:cflib.crazyflie.mem:Requesting first id
INFO:cflib.crazyflie.mem:Requesting information about memory 1
INFO:cflib.crazyflie.mem:Memory: id=1, type=LED driver, size=24
INFO:cflib.crazyflie.mem:Done getting all the memories, start reading the OWs
INFO:cflib.crazyflie:Memories finished updating
INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/80/2M]
INFO:cfclient.utils.logconfigreader:Parsing [stabilizer.json]
INFO:cfclient.utils.logconfigreader:Parsing [Mag_pure.json]
INFO:cflib.crazyflie.mem:Writing new chunk of 24bytes at 0x0
INFO:cflib.crazyflie.mem:Updating content of memory 0
INFO:cflib.crazyflie.mem:Requesting new chunk of 16bytes at 0x0
INFO:cflib.crazyflie.mem:WRITE: Mem=1, addr=0x0, status=0x0
INFO:cflib.crazyflie.mem:This write request is done
INFO:cflib.crazyflie.mem:Write to LED driver done
INFO:cfclient.ui.main:LED write done callback
INFO:cflib.crazyflie.mem:READ: Mem=0, addr=0x0, status=0x0, data=(48, 120, 66, 67, 1, 80, 2, 0, 0, 0, 0, 0, 0, 0, 0, 231)
INFO:cflib.crazyflie.mem:READING: We are still interested in request for mem 0
INFO:cflib.crazyflie.mem:Got new data: bytearray(b'0xBC\x01P\x02\x00\x00\x00\x00\x00\x00\x00\x00\xe7')
INFO:cflib.crazyflie.mem:Requesting new chunk of 5bytes at 0x10
INFO:cfclient.ui.tabs.LEDTab:Memory: id=1, type=LED driver, size=24
INFO:cflib.crazyflie.log:Have successfully started logging for id=3
INFO:cflib.crazyflie.mem:READ: Mem=0, addr=0x10, status=0x0, data=(231, 231, 231, 231, 3)
INFO:cflib.crazyflie.mem:{'radio_address': 996028180455, 'version': 1, 'pitch_trim': 0.0, 'radio_speed': 2, 'radio_channel': 80, 'roll_trim': 0.0}
INFO:cflib.crazyflie.log:Have successfully started logging for id=4
INFO:cflib.crazyflie.log:Have successfully started logging for id=5
INFO:cflib.crazyflie.log:Have successfully started logging for id=6
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.HMC5883L]: 1
INFO:cfclient.ui.tabs.FlightTab:[imu_sensors.MS5611]: 1
INFO:cflib.crazyflie.log:Have successfully started logging for id=7
INFO:cflib.crazyflie.log:Have successfully started logging for id=8
INFO:cfclient.ui.tabs.FlightTab:Changed effect to 0
[SOLVED] crazyflie artificial horizon/throttle not responding
Re: crazyflie artificial horizon/throttle not responding
The calibration routine is a bit more strict to get better values. My guess is that the sensors hasn't calibrated because the CF2 is not put on a stable enough surface? Please check the red M1 LED when powering up. It should switch to faster blinking rate (from 1Hz to 2Hz) when calibrated.
Thank you, as you said, the red led was blinking at 2 Hz, not 0.5 Hz. Moving to a stable flat surface for calibration solved my problem of motors not responding.
