When I try and run it. Any ideas?CRITICAL:cfclient.gui:No pysdl2 installation found, exiting!
Win Conda 64-bit - No pysdl2 installation found
Trying to get the cfclient running under 64-bit Anaconda because I want to use the large memory for some things. I followed the instructions here (https://github.com/bitcraze/crazyflie-c ... /README.md) but now I am getting:
Re: Win Conda 64-bit - No pysdl2 installation found
Okay, by looking at the installation messages I realized I was getting the 32-bit SDL. So I downloaded the current version from https://www.libsdl.org/release/. I used the version SDL2-2.0.4-win32-x64.zip.
Now it starts at least (opens the window and I can operate) but it can't seem to find the crazyfile radio dongle, even though the cfclient running in my Ubuntu VM sees it just fine...
I am also getting the message:
which could be related I suppose.WARNING:cflib.crtp.usbdriver:Exception while scanning for Crazyflie USB: No backend available
Okay, fixed that one too. Had to install another usb library from https://sourceforge.net/projects/libusb ... s/1.2.6.0/
I downloaded libusb-win32-devel-filter-1.2.6.0.exe and installed it, then configured it with "INFwizard" to filter to the two Crazyflie devices, "Crazyflie 2.0" and "Crazyradio PA USB Dongle".
Some docs on libusb here: http://www.libusb.org/wiki/libusb-win32.
After that it worked fine and I could control it with my Sabrent USB PS3 controller. Worked better when I selected the interface to be USB://0 rather than radio://0... - the latter drops packets and disconnects, have to look into that next.
