Modelling and Control of Crazyflie
Posted: Thu Mar 05, 2020 9:37 am
by Calvin Chua
Hi, I am a new user to crazyflie. Is it possible to code using cflib to control the speed of individual motor instead of using the prebuilt function such as forward() etc. Besides, I am thinking of model the crazyflie and is it possible that could you provide me some system parameters of Crazyflie 2.1 such as moment of inertia please? I found some references from others research but they are slightly different I am worried about the accuracy of the parameters.
Thanks Regards,
Calvin
Re: Modelling and Control of Crazyflie
Posted: Thu Mar 05, 2020 10:07 am
by tobias
First thing there is a paper about the modeling of the crazyflie in the bottom of the "Publications involving Crazyflie 2.X"
here. You will find a lot of details there and it is still true for the 2.1.
As for controlling
individual speed of the motors this is possible but maybe not the way you want to do it. If you want to run the lowest level, rate controller, on a PC instead the latency becomes a problem. I think the quickest round-trip time currently achieved is around 4ms and then the communication has to be changed a bit to minimize latency. Maybe you can share a bit more what you want to achieve so it will be easier for us to guide you?
Posted: Thu Mar 05, 2020 10:29 am
by Calvin Chua
Hi Tobias,
Thanks for your reply. At the moment, I am planning to implement the control of aggresive maneuver using Crazyflie, which propably needs to control the speed of motors independently to achieve the required flying pattern.
Posted: Thu Mar 05, 2020 2:26 pm
by tobias
Then I think you want to
control the rate (rotation speed) and not the motors directly. Unfortunately this has not yet been implemented in the crazyflie firmware or lib. It should be part of the
commander and I suggest you create a issue in the crazyflie-lib-python repo to suggest to add it. If you have the possibility please give it a try yourself. That would be the quickest way to get it done.
