Help with Crazyradio in python
Posted: Sat Feb 14, 2015 5:43 am
I recently obtained a Crazyflie 2.0 for the explicit purpose of doing some simple developmental work as a side hobby. As background I know a bit of python but have spent the last few days trying to set up the dev environment on my PC.
After installing all the required drivers and python requirements, I am having an odd problem where the crazyradio scan function won't pick up my crazyflie. This is odd because when I open the cfclient and scan I find the crazyflie easily.
My code is below, I don't think that it is a specific coding issue as this is from the ramp.py example folder. Any thoughts or ways I can better figure out what might be going on?
import sys
sys.path.append("../lib")
import cflib.crtp
print "Scanning interfaces for Crazyflies..."
available = cflib.crtp.scan_interfaces()
print "Crazyflies found:"
for i in available:
print i[0]
if len(available) > 0:
print "Crazyflies located - have fun!"
else:
print "No Crazyflies found, cannot run example"
