[SOLVED] Enabling and using the UART Rx interrupt
roeiz
Post by roeiz »
Hi bitcraze community,
I'm trying to enable and use UART1, and more specifically, the Rx interrupt.
I have created a deck and connected a sensor I've built to the CF2 UART1 Rx pin (PC11). My sensor does transmit data over the UART as I'm seeing the expected signal using a scope.
While the CF2 UART1 initializing and testing functions do seem to work (I changed the uart1Test function to flash some LEDs), I cannot seem to use the Rx interrupt (USART_IT_RXNE).
Of course I have enabled UART1 in the config file with
ENABLE_UART1
and as I wrote above, this part works.
The IRQ handler in uart1.c is as following:
void __attribute__((used)) USART3_IRQHandler(void)
  uint8_t rxData;
  portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
  if (USART_GetITStatus(UART1_TYPE, USART_IT_RXNE))
    rxData = USART_ReceiveData(UART1_TYPE) & 0x00FF;
    xQueueSendFromISR(uart1queue, &rxData, &xHigherPriorityTaskWoken);
    portYIELD_FROM_ISR(xHigherPriorityTaskWoken);
and uart1Getchar function in uart1.c was changed so I can easily see if it is being executed:
int uart1Getchar(char * ch)
  xQueueReceive(uart1queue, ch, portMAX_DELAY);          // Should be blocked on queue until USART3_IRQHandler is executed
  return 1;
Finally, I am creating the following task:
static void spinTask()
	int i = 0;
	char angle[] = "000\n\r";
	systemWaitStart();
	while (1)
		i = uart1Getchar(angle);        // Will be set to 1 if uart1Getchar function executes
		while (i)
			ledSet(1, 0);
			vTaskDelay(M2T(100));
			ledSet(1, 1);
I am expecting to see the LEDs flashing after CF2 receives the signal over UART, however, nothing happens.
Is there anything I need to do in order to enable the use of the Rx interrupt?
I did see that the uart1Init function includes these two lines:
USART_ITConfig(UART1_TYPE, USART_IT_RXNE, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
Please advise on how should I proceed :)
Re: Enabling and using the UART Rx interrupt
What baudrate is the sensor. Maybe there is a miss-match in the baudrate?
I just updated the UART drivers with DMA transfer funcitons today and then the RX worked without problem.
roeiz
Post by roeiz »
Both baudrates (sensor's and CF2's) are matched at 9600.
Tobias,
Is there anything needed to be done in order to enable/use the Rx?
Am I doing anything wrong?
Should I use taskToNotify or relying on the queue to block/unblock is good enough?
Would appreciate any help or lead :)
I added two tests for uart1 and uart2. They are just echoing what ever you send in. I used a 3.3v FTDI cable connected to the uart signals. You could try it. You need to add the uart1test.c in the makefile and add "CFLAGS += -DDECK_FORCE=bcUart1Test" to you config.mk file.
roeiz
Re: [SOLVED] Enabling and using the UART Rx interrupt
Post by roeiz »
Apparently I missed a baudrate define, changing it solved the issue.
Thanks Tobias! :D
