eeprom
Re: eeprom
Well I think you found a typo is ST CPAL lib. The pin source should match the pin so it should be GPIO_PinSource8
/*----------- I2C1 Device -----------*/
#define CPAL_I2C1_SCL_GPIO_PORT         GPIOB
#define CPAL_I2C1_SCL_GPIO_CLK          RCC_AHB1Periph_GPIOB
#define CPAL_I2C1_SCL_GPIO_PIN          GPIO_Pin_8
#define CPAL_I2C1_SCL_GPIO_PINSOURCE    GPIO_PinSource8
#define CPAL_I2C1_SDA_GPIO_PORT         GPIOB
#define CPAL_I2C1_SDA_GPIO_CLK          RCC_AHB1Periph_GPIOB
#define CPAL_I2C1_SDA_GPIO_PIN          GPIO_Pin_7
#define CPAL_I2C1_SDA_GPIO_PINSOURCE    GPIO_PinSource7
The pull-up should be connected to VCC somewhere along the SCL line. You can do it on the expansion board if that is easiest.
Che.
Re: eeprom
Post by Che. »
When I assign
Pin 8 to Source 8,
my Crazyflie wont start up properly.
When switching it back to
Pin 8 to Source 7, (as described in the table)
the Crazyflie starts up. But i wont get a reading.
NAMELY THIS IS MY READING:
B8 3A BE BE BE BE BE BE BE BE BE BE BE BE BE BE
Status 5
That maybe another problem when calling the bitcraze i2c-functions.
Is my approach the right one?
1.) initialize I2C1 device
i2cdevInit(I2C1_DEV);
2.) perform signal acquisition (LIDAR2 Internal)
i2cdevWriteByte(I2C1_DEV, 0x62, 0x00, 0x04);
Where 0x62 is the adress of the LiDAR...
3.) xTaskCreate my polling-task
4.) vTaskDelayUntil in polling task to make sure i wont overpoll anything
5.) Read byte
i2cdevReadByte(I2C1, 0x62, 0x10, pData);
6.) Console Printing
DEBUG_PRINT("pData:                %i\n", *pData);
tobias wrote:The pull-up should be connected to VCC somewhere along the SCL line. You can do it on the expansion board if that is easiest.
You mean soldering a resistor between SCL-pin and VCC?
How much ohms do i need there?
Sorry for those noobish questions.
Greets,
Che
Re: eeprom
4.7kOhm should be fine but anything from 2k - 10k probably works.
When I assign Pin 8 to Source 8, my Crazyflie wont start up properly.
Have you tries disabling the eeprom i2c reading? To me using pin source 7 on pin 8 is wrong. You can check the datasheet to confirm.
Che.
Re: eeprom
Post by Che. »
soldering of the resistor and disabling the configblock initialisation did the trick.
The Problem now is that i get the NACK-Error (0x400) from my I2CDEV. I really don't know how to handle this error.
CPAL_I2C_IsDeviceReady() gives me positive feedback.
but when calling i2cdevReadByte() i get the above error (CPAL_I2C_ERR_AF).
Do you have suggestions? I read in the cpal_i2c.h, the following:
A transmitter which receives a NACK must reset the communication:
                                          - If Slave: lines are released by hardware.
                                          - If Master: a Stop or repeated Start condition must be generated
                                            by software.
                                         Software Clearing sequence for the ARLO bit:
                                         1. Writing '0' to this bit */
Do you have a suggestion how to solve this? Its very confusing to me, as I need to constantly jump between all levels of the system.
Thanks for any hints!
Greets, Che
atomicdog
Re: eeprom
Post by atomicdog »
Is the read during a setup/init of the I2C device or are you just testing if it works by doing a random read?
Some I2C devices need to be setup up properly before they respond, so if you just tried to read a random register it wouldn't respond.
Che.
Re: eeprom
Post by Che. »
Hi atomicdog, thanks for your answer!
atomicdog wrote:Is the read during a setup/init of the I2C device or are you just testing if it works by doing a random read?
First, I initiate the I2C-Device in the STM32 chip with i2cdevInit(I2C1_DEV).
Then I test, if the device is ready with CPAL_I2C_IsDeviceReady(I2C1_DEV).
I start my Task and then
in the last step I try to read the status of the I2C-Peripheral by calling the function i2cdevReadByte(I2C1_DEV, LIDARLITE_ADDRESS, LIDARLITE_REG_STATUS2, pData).
(STATUS2 is not a typo here)
atomicdog wrote:Some I2C devices need to be setup up properly before they respond, so if you just tried to read a random register it wouldn't respond.
I read int the manual, that i need to write to some registers to get the actual distance measurement routine started. but first i wanted to check if i could read anything in the first place.
Trying to set up the registers to the writing mode result in the same error though.
atomicdog
Re: eeprom
Post by atomicdog »
I haven't worked with this code base in a long time but it looks like you're using two different I2C libraries to me. If you're using CPAL it seems like all the I2C function should start with CPAL_ ?
What is I2C1_DEV? Doing a quick look at the functions it doesn't seem to make sense to pass in I2C1_DEV to both i2cdevReadByte() and CPAL_ functions.
Posting more of your code will make it easier to see what you're doing.
Che.
Re: eeprom
Post by Che. »
There is an interface written by bitcraze on top of the CPAL, as far as i understand, which lets you access the i2c-device. But I think I haven't completly understood how this bitcraze-interface works. I mentioned earlier, that its a bit confusing to switch between those levels. I might post my complete code here, which I see i shouldve done much earlier anyway :D
I2C1_DEV is just a define by bitcraze for the &I2C1_DevStructure.
#define DEBUG_MODULE "RANGE"
#include <string.h>
#include "FreeRTOS.h"
#include "task.h"
#include "config.h"
#include "range.h"
#include "system.h"
#include "param.h"
#include "log.h"
#include "i2cdev.h"
#include "cpal_i2c.h"
#include "lidarlite.h"
#include "debug.h"
#include "eprintf.h"
#include "cpal.h"
#include "stm32fxxx.h"
/* Internal values exported by functions below. */
static uint16_t rangeDistance = 0;
uint8_t status = 0;
uint8_t *pData;
uint8_t data;
static void rangeTask(void* param)
	DEBUG_PRINT("Start of rangeTask()\n");
	uint32_t lastWakeTime;
	vTaskSetApplicationTaskTag(0, (void*)TASK_RANGE_ID_NBR);
	//Wait for the system to be fully stated to start stabilization loop
	//systemWaitStart();
	lastWakeTime = xTaskGetTickCount();
	while(1)
		vTaskDelayUntil(&lastWakeTime, F2T(RANGE_TASK_FREQ));
		DEBUG_PRINT("rangeTask running\n");
		//RESET FPGA
		i2cdevWriteByte(I2C1_DEV, LIDARLITE_ADDRESS, 0x00, 0x00);
		//PERFORM SIGNAL ACQUISITION
		//I2C-Address of LIDAR: 0x62
		i2cdevWriteByte(I2C1_DEV, LIDARLITE_ADDRESS, 0x00, 0x04);
		i2cdevReadByte(I2C1_DEV, LIDARLITE_ADDRESS, LIDARLITE_REG_STATUS2, pData);
		data = (unsigned int)pData;
		if (data & LIDARLITE_STAT_BUSY) DEBUG_PRINT("busy \n");
		if (data & LIDARLITE_STAT_REF_OVER) DEBUG_PRINT("reference overflow \n");
		if (data & LIDARLITE_STAT_SIG_OVER) DEBUG_PRINT("signal overflow \n");
		if (data & LIDARLITE_STAT_PIN) DEBUG_PRINT("mode select pin \n");
		if (data & LIDARLITE_STAT_SECOND_PEAK) DEBUG_PRINT("second peak \n");
		if (data & LIDARLITE_STAT_TIME) DEBUG_PRINT("active between pairs \n");
		if (data & LIDARLITE_STAT_INVALID) DEBUG_PRINT("no signal \n");
		if (data & LIDARLITE_STAT_EYE) DEBUG_PRINT(" eye safety \n");
void rangeInit(void)
	if(CPAL_I2C_IsDeviceReady(I2C1_DEV) == CPAL_PASS){
		DEBUG_PRINT("I2C1_DEV ready for communication...\n");
	else{
		DEBUG_PRINT("I2C1_DEV not ready..\n");
	xTaskCreate(rangeTask, (const signed char * const)RANGE_TASK_NAME,
			RANGE_TASK_STACKSIZE, NULL, RANGE_TASK_PRI, NULL);
	DEBUG_PRINT("End of rangeInit()\n");
uint32_t rangeGetDistance(void)
	return rangeDistance;
Che.
Re: eeprom
Post by Che. »
I think the problem may be, that the CPAL doesn't send any Stop-Conditions after reading, which doesn't work with the sensor.
