CF2 self-test fails
Posted: Sun Nov 25, 2018 1:01 pm
by flux
Self-test fails all the time, when i power on my CF2.
When connecting to the Crazyflie PC client, I get this from the Console:
SYS: Crazyflie is up and running!
SYS: Build 164:0dbbb77772a9 (production1.1) CLEAN
SYS: I am 0x31323832313347012F001D and I have 1024KB of flash!
I2CDEV: Error callback nr: 1024
IMU: MPU9250 I2C connection [FAIL].
IMU: AK8963 I2C connection [FAIL].
IMU: LPS25H I2C connection [FAIL].
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
OW: Found 0.
30 78 42 43 0 50 0 0 0 0 0 0 0 0 0 7D
Status 0
Re: CF2 self-test fails
Posted: Mon Nov 26, 2018 1:19 pm
by arnaud
This is an I2C problem when connecting the sensors.
- Is the Crazyflie new of has it been programmed already?
- Can you try to flash the latest firmware release and send the console from this one also?
Posted: Mon Nov 26, 2018 3:03 pm
by flux
- Is got the crazyflie in 2016, but it has never been programmed by me.
- I currently don't have a crazyradio (PA) dongle, is there a method to flash it via my android device? Or does it also need a crazyradio pa?
Posted: Wed Nov 28, 2018 9:15 am
by arnaud
Unfortunatly the only way to flash a new firmware without a Crazyradio is to use the iOS app. So if you can borrow an iPhone or iPad you can flash the latest firmware with it.
Posted: Mon Dec 03, 2018 3:05 pm
by flux
So i flashed it to the latest firmware with an iphone, it said it was flashed succesfully but there is no console i can send you. The selftest still fails. Anything else i can do?
